Thread: Blowing Air Conditioning Fuses
Results 1 to 2 of 2
  1. #1 Blowing Air Conditioning Fuses
    GT Level Member ls1camino's Avatar
    Laurel, MD
    This is on my brother's 2000 Grand Am 3.4L.
    When he bought the car, the AC worked fine, two weeks ago it went out for no reason. I thought it was a fuse, and I replaced 3 different HVAC fuses (one on the passenger side interior and 2 under the hood). Nothing changed, so I figured it was the blower motor. While pulling appart the interior to replace the blower motor, I noticed ANOTHER fuse panel, this time on the passenger side interior. I pulled the cover off and found another HVAC fuse (20A). I pulled it and found it was blown. So, I replaced it with another 20A, and as soon as my brother turned the ignition to ON (didn't start the car) the replacement fuse blew. I didn't have another 20A, so I replaced it with a 30A. Turned that ignition to ON and that one popped too. I'm lost as to why this is happening. Stock is 20A, but it's not even lasting a second upon startup.
    What should I check next?
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: Blowing Air Conditioning Fuses
    You should pull the connector off the ac compressor and multimeter it to (ohm) ground. See if something is grounding it. Then find the relay and check that.
  1. Question bout 88 GP fuses
    By MarkUSAF in forum General Tech Discussion
    Last Post: 07-20-2011, 12:20 PM
  2. Eating fuel pump fuses
    By YeahRight in forum General Tech Discussion
    Last Post: 07-19-2011, 11:02 AM
  3. RAP and Power Drop fuses
    By Warbeaver in forum Audio, Security & Visual Electronics
    Last Post: 05-17-2010, 08:53 PM
  4. Popping Cooling Fan1 fuses like MAD!
    By Phils02GT in forum General Tech Discussion
    Last Post: 06-17-2009, 11:39 AM
  5. HID Fogs keep blowing fuses. Wtf?
    By TheDesertFox in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2009, 01:11 PM
