When it does this, pop the plastic cover off the bottom of the column near the ignition switch and use a pen or something small to press the white plastic tab inside there and the key should release. And no, you just need to replace the ignition switch, not the tumbler so you can retain your original key. Search for stuck ignition key here on the forums for better details as this is common.
