Thread: Ignition key, won't turn to off position
Results 1 to 3 of 3
  1. #1 Ignition key, won't turn to off position
    Virginia
    I have an 03, GT. For some reason when I turn the key off, it won't go to the off position. About 50% of the time I can get it to go to the auxillary position then move it forward to the off. But that only occurs if after drivig it , putting it in park, holding down the brake with significant force, pushing in on the key and turning it. My wife can't do it no matter how many time I show/explain it. Im tired of jumping the car as the battery keeps draining as a result.
    It sounds to me like I may need to change the ignition key out. But then I'll have to re-key the trunk and glovebox as they come with their own keys. Anybody know of any other fix?
  2. #2 Re: Ignition key, won't turn to off position
    St. Louis
    When it does this, pop the plastic cover off the bottom of the column near the ignition switch and use a pen or something small to press the white plastic tab inside there and the key should release. And no, you just need to replace the ignition switch, not the tumbler so you can retain your original key. Search for stuck ignition key here on the forums for better details as this is common.
  3. #3 Re: Ignition key, won't turn to off position
    Aug 2011
    'Merica
    I didn't replace anything. I just press the tab and go.
  1. Ignition will not turn to start position
    By glovey in forum General Tech Discussion
    Last Post: 08-08-2011, 03:51 PM
  2. Ignition stuck in OFF position
    By chilipepperpizza in forum General Tech Discussion
    Last Post: 06-29-2010, 07:25 PM
  3. 2001 Grand Prix ignition off position adjustment
    By davejt in forum Introductions/Noob Questions
    Last Post: 06-16-2010, 11:35 PM
  4. 2001 Grand Prix ignition switch position
    By davejt in forum General Tech Discussion
    Last Post: 06-15-2010, 11:07 PM
  5. HELP! Ignition key will not turn in 1994 SE
    By cerdman in forum General Tech Discussion
    Last Post: 08-10-2009, 12:09 AM
