Thread: Uh what did i just accidently break...
Results 1 to 15 of 15
  1. #1 Uh what did i just accidently break...
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Its a pretty cold day here, and I was just reaching under the SC snout when my hand accidently broke this skinny piece of plastic. It literally took no effort at all, i barely touched it. The car hasn't had any problems, i took it for a ride and everything. Help?
    Please excuse how horrifyingly disgusting my engine bay is.
  2. #2 Re: Uh what did i just accidently break...
    Can't see the picture at work.
    I'm assuming it is the vacuum line.
    You can get a full set of non-dry rotted ones from your local dealership.
  3. #3 Re: Uh what did i just accidently break...
    It's a vacuum line. Pull out the old piece in teh rubber and stuff the remaining piece in it. That'll get you by for now.
    Jan 2009
    Tallahassee, FL
    That's the vacuum line for your fuel pressure regulator, you need to fix that soon. I think you'll be ok just normal driving, just don't go into boost.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: Uh what did i just accidently break...
    Pennsylvania
    Might take some needle-nose pliers, but pull the busted piece of plastic out of the rubber and shove the remaining hose in like Bill said.
  6. #6 Re: Uh what did i just accidently break...
    That'll be a direct leak when not in boost into the LIM.
    It'll jack up fuel pressure and the pcm will compensate through fuel trims
    When under boost..it won't make a difference
    Sooo stick it back in ... please.
  7. #7 Re: Uh what did i just accidently break...
    Oct 2011
    New Jersey
    So i tried to take out rubber...it was basically like a rock. Sadly i ended up breaking the other one too. The entire line in front of my engine was dry-rotted to ****. even the T connector thing broke, same with the right side. With no lines, can i still make it to Advanced Auto to get everything i need?
  8. #8 Re: Uh what did i just accidently break...
    I live here. TLSheff's Avatar
    GM# 24508742 - Retail $47.53 from a dealer. Search Rockauto for the hose kit with that number and see if you can get it cheaper.
    It is basically just the vacuum harness that goes between the supercharger bypass valve, fuel pressure regulator, lower intake manifold, and map sensor. If its broken/brittle, it NEEDS to be replaced.
    Jan 2009
    Tallahassee, FL
    I just bought some rubber vacuum hose and a couple of t-fittings and rebuilt the vacuum system for cheap.
    77 Morris Garage B
  10. #10 Re: Uh what did i just accidently break...
    utah
    ^this....pftt pay 50 bucks for 15 bucks worth or vac line and t's
  11. #11 Re: Uh what did i just accidently break...
    Quote Originally Posted by boostedcompg View Post
    Some people would prefer to spend the money on the OEM equip... just giving options.
  12. #12 Re: Uh what did i just accidently break...
    Jan 2009
    Tallahassee, FL
    Rubber hose lasts longer and is much more forgiving than cheap plastic lines.
    77 Morris Garage B
  13. #13 Re: Uh what did i just accidently break...
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    I had to replace the whole assembly on my GTP this past summer. Dealer only part, about $30 iirc
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  14. #14 Re: Uh what did i just accidently break...
    Sheffer is giving you guys the retail cost from his dealership in that $50 number. I've never heard of anyone paying much more than $30 for OEM lines.
  15. #15 Re: Uh what did i just accidently break...
    Oct 2011
    New Jersey
    I just went to advanced auto and got some t-connectors and rubber vacuum line. Time to change the coupler i just got in the mail now
  1. What did i break?
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 08:30 PM
  2. help me break 13's :/
    By 99prixgt in forum General Tech Discussion
    Last Post: 04-25-2010, 02:03 PM
  3. First Break down
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-05-2010, 01:24 AM
  4. Break n oil
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-13-2009, 11:27 PM
  5. not new but took a break
    By WhiteDevil in forum Introductions/Noob Questions
    Last Post: 10-06-2009, 07:59 AM
