Thread: HVAC Blower Motor
Results 1 to 3 of 3
  1. #1 HVAC Blower Motor
    Dec 2010
    Waterford, MI
    Is it common to have the blower come on at what seems to be a slow setting in auto mode (temp @90), and not be able to change speeds in manual?
    Usually in auto with temp at 90 the speeds goes up to max. However if in manual mode there is no change of speeds.
    Based on what I have read, I am thinking it’s the resistor.
    Maybe the BCM?
    Maybe the motor itself?
    Any help would be appreciated.
    By the way, it comes and goes.
    1998 Silver Mist ALL Stock Grand Prix GTP
  2. #2 Re: HVAC Blower Motor
    Apr 2011
    Pensacola, Fl
    It might be the blower motor itself actually. I know when I bought my GTP, I went from no blower to only max, then like half the speeds, then nothing again. Replaced the motor, and haven't had a problem for 8 months. Motors are easy to change and not to expensive. Hope it helps.
    1998 Grand Prix GTP- SLP Cold Air Intake
    2011 Ford Explorer XLT 4WD- K&N, DDM 6000K HID Kit
  3. #3 Re: HVAC Blower Motor
    Dec 2010
    Waterford, MI
    I did replace the resistor, just plugged in not installed, it worked. I did not install in case i needed to return to store.
    Now I have all kinds of hot air!
  1. HVAC Blower not working
    By 99gtpnj in forum General Tech Discussion
    Last Post: 05-29-2011, 06:32 AM
  2. Intermittent HVAC blower
    By Doc Banger in forum General Tech Discussion
    Last Post: 01-26-2011, 11:37 AM
  3. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  4. Noisy blower motor (HVAC fan )
    By ChupakabraKing in forum General Tech Discussion
    Last Post: 06-12-2009, 11:42 AM
  5. HVAC Blower Question
    By 2001camaroB4C in forum General Tech Discussion
    Last Post: 10-25-2008, 02:05 AM
