Thread: help with hids not turning on and blowing fuse
Results 1 to 4 of 4
  1. #1 help with hids not turning on and blowing fuse
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    I need help with my hids. I had them install for a while and out nothing one of them when out.I thought it was the bulb but I was wing check the fuse box and notice that right low bean fuse was blown,I replaced it and I soon I install it it blows. So I disconnect the ballast to see if the fuse would blow and it don't is the ballast bad? Any suggestion?
  2. #2 Re: help with hids not turning on and blowing fuse
    St. Louis
    Well, if you disconnected the ballast to that headlight and the fuse doesn't blow then you either have a bad ballast, or the wiring to it is bad somewhere and is grounding out. Check the wire harness for anything odd (chaffed wire, baer wire, cut wire, melted, etc..) and if you don't see anything then replace the ballast.
  3. #3 Re: help with hids not turning on and blowing fuse
    May 2011
    El paso tx
    I don't see nothing on the wiring so my ballast is bad thanks for the info
  4. #4 Re: help with hids not turning on and blowing fuse
    St. Louis
    If the ballasts are easy to get to/remove, maybe try swapping sides with them and see if the issue follows the ballast, or stays on that side. Do that all the time in the telecom world. That will tell you if the ballast is for sure bad, or if you have other issues going on.
  1. Why do i keep blowing this fuse?
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-04-2011, 09:01 PM
  2. keep blowing fuse for fog lights.
    By RyanL in forum Audio, Security & Visual Electronics
    Last Post: 10-30-2011, 01:58 PM
  3. Help with blowing reverse fuse
    By ck115 in forum General Tech Discussion
    Last Post: 08-02-2010, 09:05 PM
  4. Keep blowing Injector fuse
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 07:40 AM
  5. MAF Fuse Blowing
    By shoboy07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 07:05 PM
