Well, if you disconnected the ballast to that headlight and the fuse doesn't blow then you either have a bad ballast, or the wiring to it is bad somewhere and is grounding out. Check the wire harness for anything odd (chaffed wire, baer wire, cut wire, melted, etc..) and if you don't see anything then replace the ballast.
