I recently found my fan/heater blower motor decided to stay on EVEN after the key was turned off. I found out that the fan blower control module was considered a hot connection meaning once it was stuck closed, the motor would run constantly. I disconnected the BATT 4 fuse and replaced the fan motor control module under the dash on the passenger side. It took about 2 hours and $120.00 for the module. Then the fan worked fine, FOR A WHILE.
Now its intermittent, coming on whenever it wants when the cars running. Now there needs to be a capacitor added to the fan control module wiring harness. Once I added this part, I have no problems since. There was a GM service bulletin announcing this.
So if anyone has this issue, then this will fix the problem.
NOTE: If your fan motor stays on when the key is off, replace the fan motor control module, AND add the capacitor.
NOTE: If your fan motor works periodically, replace the capacitor ONLY.
Hope this helps those who are looking for this issue.
