Thread: Blower Motor Intermitting. I can Help
Results 1 to 8 of 8
  1. #1 Blower Motor Intermitting. I can Help
    Nov 2011
    Thompson, Canada
    I recently found my fan/heater blower motor decided to stay on EVEN after the key was turned off. I found out that the fan blower control module was considered a hot connection meaning once it was stuck closed, the motor would run constantly. I disconnected the BATT 4 fuse and replaced the fan motor control module under the dash on the passenger side. It took about 2 hours and $120.00 for the module. Then the fan worked fine, FOR A WHILE.
    Now its intermittent, coming on whenever it wants when the cars running. Now there needs to be a capacitor added to the fan control module wiring harness. Once I added this part, I have no problems since. There was a GM service bulletin announcing this.
    So if anyone has this issue, then this will fix the problem.
    NOTE: If your fan motor stays on when the key is off, replace the fan motor control module, AND add the capacitor.
    NOTE: If your fan motor works periodically, replace the capacitor ONLY.
    Hope this helps those who are looking for this issue.
  2. #2 Re: Blower Motor Intermitting. I can Help
    good info
  3. #3 Re: Blower Motor Intermitting. I can Help
    Dec 2011
    concordia
    how much did the capacitor cost and did it fix the comes and goes with bumps in the road problem
  4. #4 Re: Blower Motor Intermitting. I can Help
    Nov 2011
    Thompson, Canada
    I also replaced the resistor and blower motor just yesterday and the cost was 345.00. So far its working. The blower motors working great now.
    The capacitor only cost $10.00 but it did not solve the problem like it was suppose to do.
  5. #5 Re: Blower Motor Intermitting. I can Help
    Illinois
    I had the intermittent problem, and found a wire (E) on the harness connector at the resistor was bad. Spliced in a new connector today, and fixed the problem. Just another thing to check if you're having this problem. Good info. wball.
  6. #6 Re: Blower Motor Intermitting. I can Help
    Nov 2011
    Thompson, Canada
    Thanks, whatever to do to help others with this problem. It seems to be a popular problem to.
    Oh, glad to hear you found a wiring problem at the resistor. That will save a few dollars. Good job.
  7. #7 Re: Blower Motor Intermitting. I can Help
    Illinois
    Thanks wball. Yeah, the connector was $35.00, labor $0. If I ever have to change the control module/capacitor, I may ask you for a detailed procedure on how you did it. Nice when someone posts a thread to help everyone else. Much appreciated.
  1. blower motor
    By Cobras 98 Prix in forum Buick Regal
    Last Post: 09-13-2011, 11:03 PM
  2. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  3. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  4. blower motor
    By bwhicker649 in forum General Tech Discussion
    Last Post: 12-02-2009, 05:13 PM
