Thread: CV joint stuck?!
Results 1 to 20 of 35
  1. #1 Re: CV joint stuck?!
    Nov 2010
    We need to replace the cv joint because of a vibration. My husbands slidehammer set has every accessory except the spoon like cv joint remover. We can purchase it but it will be at least a week before we get it and he is doubtful that will work. We are just trying to figure out what may cause the shaft to be stuck in the tranny. He's pulled alot of cv joints an never had one stick this bad.
  2. #2 Re: CV joint stuck?!
    SWPA
    Had one that stuck really bad on one of my brother's Neons once.
    We tried lots of different things, even devising a two man puller and it still wouldn't budge. We ended up using a chisel to a gap started between the axle and the case. After that got the chsiel in a good position and hammered on it til the axle finally popped.
  3. #3 Re: CV joint stuck?!
    Nov 2010
    He thought of trying that but the subframe is in the way plus the tranny case is aluminum and he's afraid he'll crack it.
  4. #4 Re: CV joint stuck?!
    SWPA
    Quote Originally Posted by chiana4477 View Post
    The case is thick, probably thicker than that of a Neon.
  5. #5 Re: CV joint stuck?!
    Denver
    Can you rent one from your local store? I know my local Checker rents tools out like this.
  1. cv joint question
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 05-01-2011, 03:05 PM
  2. Need gtp flex joint.
    By Dirt Diggin GTP in forum Introductions/Noob Questions
    Last Post: 08-09-2010, 11:06 AM
  3. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  4. Steering / CV Joint?
    By Egleone6 in forum General Tech Discussion
    Last Post: 04-08-2009, 11:08 PM
  5. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
