Thread: damn rusty exhaust bolts!
Results 21 to 40 of 53
  1. #21 Re: damn rusty exhaust bolts!
    Kj.. you chose the hard way. Subframe lowering is the key.
    Spade..I agree. My ingersol 3/8 loves to get those bolts "loose" quickly..lol I've never had an issue on the head bolts. Cept for one that I'm sure had been messed with in it's past.
  2. #22 Re: damn rusty exhaust bolts!
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    Yea i did it by myself subframe lowering was not an option
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  3. #23 Re: damn rusty exhaust bolts!
    You need more/better tools.
  4. #24 Re: damn rusty exhaust bolts!
    Quote Originally Posted by klj5022 View Post
    I did mine myself and lowered the subframe. Why is it not an option? Do you not have a jack?
  5. #25 Re: damn rusty exhaust bolts!
    i used a bottle jack and a masonry wall block to sit the jack on. its amazing what 2 or 3 inches of drop can do for more room.
  6. #26 Re: damn rusty exhaust bolts!
    New Carrollton,MD
    I only have a jack and two jack stands and alot of rust partial reason is i was worried about bolts stripping or brreaking GF just movd to NO so no ride to autoparts store
  7. #27 Re: damn rusty exhaust bolts!
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Bringing this back to life.. tried the other bolt on other side where downpipe connects under the car this weekend. Used propane torch to heat it forever and went at it and surprise surprise... snap!! So yea I had to drill out another one. Looking where the downpipe meets the header looks like a tough spot and I'm thinking if the bolt snaps there, I'm kinda screwed. Took to exaust shop and they quoted me 90 to do it... but instead of replacing whole thing, they are planning on cutting stock pipe up towards the headers then cutting the downpipe I want to install to match and weld it... I guess they are scared of the bolts snapping also? Think that is a good plan? Sounded strange to me that they wouldn't just install it the normal way..
  8. #28 Re: damn rusty exhaust bolts!
    Oct 2011
    Reading PA
    Also sucks because I won't be able to sell the stock one... and yes, this is a reputable exhaust shop in my area
  9. #29 Re: damn rusty exhaust bolts!
    SWPA
    They are being lazy. If you are going to pay someone to do this, do it the right way. The bolts that bolt from the crossover to the downpipe should come out with ease.
  10. #30 Re: damn rusty exhaust bolts!
    Oct 2011
    Reading PA
    Yea I was speechless... and everytime I hinted not to do that they seemed like they weren't paying any attention. I was under the impression the bolts closer to the headers would be more likely to snap? They are less likely then the ones connecting it under the car?
  11. #31 Re: damn rusty exhaust bolts!
    My crossover to rear mani one bolt snapped and the rear mani to dp came out with ease, and by ease i mean an impact and 2 ft of ext.
  12. #32 Re: damn rusty exhaust bolts!
    Oct 2011
    Reading PA
    Yea I don't have impact tools... think ill have same success with regular hand tools and 2 ft extension?
  13. #33 Re: damn rusty exhaust bolts!
    possibly just a lot more wrenching. Make sure you spray some pb blaster on there first
  14. #34 Re: damn rusty exhaust bolts!
    Oct 2011
    Reading PA
    Yea I heard that before... did that for like an hour every 10 minutes almost whole can on ones underneath that snapped right away... maybe ill try the everyday technique for a week..... if one of those breaks off I'm pretty much F'ed huh?
  15. #35 Re: damn rusty exhaust bolts!
    Pretty much lol. Then it's header time
  16. #36 Re: damn rusty exhaust bolts!
    Oct 2011
    Reading PA
    Hahaha... good thing I always have hundreds of dollars laying around.... oh wait, I'm broke at the moment. . So... pay to get it done after I pay bills, try to soak the bolts everynight for a week, or say F it and sell it. Decisions decisions...
  17. #37 Re: damn rusty exhaust bolts!
    New Carrollton,MD
    i punked out and got local shop to put it on for me and they only charged 40
  18. #38 Re: damn rusty exhaust bolts!
    Oct 2011
    Reading PA
    Must be a nice local shop... I think 90 is a bit on the high end for direct bolt on replacement... maybe ill check around a bit
  19. #39 Re: damn rusty exhaust bolts!
    The lower bolts are more prone to rust. The upper bolts from rear manifold to DP are stout. They typically don't snap.
    The tools I use are a 2" extension, ball pivot snap on deep socket and a 3/8" ratchet with a long handle. Yes..now a days I use air..but for the longest time..I simply crawled under with the listed tools. I think I've broken only one stud over the years on teh manifold to DP connection. And if you are doing headers..then it doesn't matter if they break.
    Want a tip.. read my tip earlier. Warm the car up, put it on stands and loosen any bolts you think you don't want to snap.
  20. #40 Re: damn rusty exhaust bolts!
    New Carrollton,MD
    i used those tools too take of DP without snapping and had driven the car about 20mles before starting and mine didnt snap neither did the lower ones
  1. exhaust manifold bolts
    By jaredbos 1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-25-2010, 12:09 AM
  2. Stubborn Exhaust Bolts
    By Thexissilent in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2010, 12:53 PM
  3. exhaust manifold bolts
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 10:09 PM
  4. Stock exhaust Bolts
    By Spartan GL in forum General Tech Discussion
    Last Post: 03-14-2010, 10:42 PM
  5. Exhaust Manifold bolts
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 06:05 PM
