Thread: exhaust manifold bolts
Results 1 to 9 of 9
  1. #1 exhaust manifold bolts
    Dec 2010
    Michigan
    can anyone tell me if there is a way and how i can remove the end stud bolts that run out of the head and connect the exhaust manifold? 99 GT 3800
  2. #2 Re: exhaust manifold bolts
  3. #3 Re: exhaust manifold bolts
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    sometimes that doesnt work use 2 nuts on the end and torque the first nut backwards and it should come out.
    1997 GTP 2DR RaceKAR
    1994 Z28 intake, small cam, exhaust leak
    2000 silverado 5.3l Z71 3.73gear posi, 3.5" lift 33" tires DIABLO Tune
  4. #4 Re: exhaust manifold bolts
    GT Level Member rolyat's Avatar
    OKC
    ^^ This
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  5. #5 Re: exhaust manifold bolts
  6. #6 Re: exhaust manifold bolts
    Dec 2010
    Michigan
    yeah.. thats not what im talking about.. im talking about the studs that the exhaust manifold hangs on.. one of them is in the way of getting a head bolt out of the side of the head
  7. #7 Re: exhaust manifold bolts
    Charles City, IA
    yeah put one nut on half way down, then tighten another one on it then back the inside one out and it will pull the stud out. Or buy a stud extractor.
    SMGPFC Two Nipple General
  8. #8 Re: exhaust manifold bolts
    Dec 2010
    Michigan
    ahhh.. i understand now.. thanks
  9. #9 Re: exhaust manifold bolts
    Charles City, IA
    no problem.
  1. Stubborn Exhaust Bolts
    By Thexissilent in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2010, 12:53 PM
  2. exhaust manifold bolts
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 10:09 PM
  3. Stock exhaust Bolts
    By Spartan GL in forum General Tech Discussion
    Last Post: 03-14-2010, 10:42 PM
  4. exhaust manifold ?
    By 04GTPCOMPG in forum General Tech Discussion
    Last Post: 11-09-2009, 03:20 PM
  5. Exhaust Manifold bolts
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 06:05 PM
