Thread: Mass Airflow Sensor question
Results 1 to 4 of 4
  1. #1 Mass Airflow Sensor question
    Nov 2011
    Texas
    I did not find a previous answer to my question regarding my [1998 Grand Prix GTP 3800 Supercharged] MAF sensor so:
    After cleaning my MAF sensor [with MAF cleaner spray] and the screen that precedes it, due to symptoms pointing to its malfunction; the problems still persist. Sometimes it shudders at or returning to idle and has twice now had problems staying started if it has run for 5 minutes or so on an errand and been restarted. NOTE: The free code check at Autozone was supposedly not specific enough to reveal all, though I have now looked up the specific codes for the MAF given in the forum's GM OBDII chart.
    Questions:
    1. Is there a reliable test that I can do myself that will insure that I must buy another before throwing the $ in the wind?
    2. Anyone know where the best price can be had if I do have to buy one?
    Thanks,
    Dean10e
    Last edited by Dean10e; 11-11-2011 at 04:12 PM. Reason: Added model and engine info.
  2. #2 Re: Mass Airflow Sensor question
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    1) Unplug the sensor drive around if the problems go away then its the sensor.
    2) junk yards could be an option.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Mass Airflow Sensor question
    Nov 2011
    Texas
    Thanks much for the simple test. I have considered doing just that, but with the hassle it's been so far, I didn't want to risk making things worse without some bad influences to encourage that.
    Am I to presume that unplugging it would isolate it from interfering with start and idle issues, but running without it would greatly reduce mileage?
  4. #4 Re: Mass Airflow Sensor question
    Hagerstown,Md
    Maybe. The pcm will go back to the VE table by default when the maf's unplugged. I dont you would see a huge differance. Id get a maf asap if you find its the issue
  1. GM 85mm LS6 LQ4 MAF Mass Airflow kit
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2017, 06:08 PM
  2. P0102 MAF mass airflow meter code low gas mileage
    By thanospl in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 03:25 PM
  3. mass airflow sensor issue,
    By will54768 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2010, 01:19 AM
  4. Mass airflow sensor troubles!
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 03:33 PM
  5. Where is mass airflow sensor on 3800?
    Last Post: 11-18-2008, 11:10 PM
