Thread: Wiper Blade Position
Results 1 to 7 of 7
  1. #1 Wiper Blade Position
    Feb 2010
    Wichita
    Well I have another anomoly with my 2000 GTP. The new windsheild wiper park position is now at 12oClock. Do any of you guys know what is causing this and what is required to repair.
  2. #2 Re: Wiper Blade Position
    Likely it's the module on the side of the motor. Was this after a windshield replacement?
  3. #3 Re: Wiper Blade Position
    Feb 2010
    Wichita
    after using during rain storm
  4. #4 Re: Wiper Blade Position
    michigan
    More than likely the bolt that holds the wiper arm. They loosen up a bit and they loose their position. Mine does that every once in awhile. Turn wipers off, turn car off, open hood, pop off plastic bolt cap on bottom of arm, 13mm bolt. Loosen bolt, move wiper arm down by hand then tighten bolt. Hope this helps.
  5. #5 Re: Wiper Blade Position
    Feb 2010
    Wichita
    Thank I will give it a shot tonight
  6. #6 Re: Wiper Blade Position
    The arms sit on splines. The bolt only holds the arm down on the splines.. .
  7. #7 Re: Wiper Blade Position
    michigan
    Idk, seems to fix mine when they become off.
  1. Wiper Home-Position
    By KZOO3800 in forum General Tech Discussion
    Last Post: 04-01-2022, 12:27 PM
  2. Cam Position Sensor
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 08-23-2011, 04:21 AM
  3. blade
    By blade in forum Introductions/Noob Questions
    Last Post: 03-29-2009, 11:02 AM
  4. IAC Position
    By Reptile in forum PCM Tuning
    Last Post: 03-08-2008, 02:21 PM
