Thread: battery cable boondoggle!!
Results 1 to 20 of 27
  1. #1 battery cable boondoggle!!
    Donating Users falconjohnd's Avatar
    Aug 2011
    new fairfield ct
    Changed my positive cable on my 98 GTP. Perfectly running car but cable was green. Now I got nothing!!! No click noo nothing. Idiot lights on dashboard come on even with key off but are lit faint. Did I fry something like a relay? How do I test them. did I do wrong here this is three easy connections!!!
  2. #2 Re: battery cable boondoggle!!
    the cable to the starter?
    if you spun the stud on the starter, well it broke off from the back side of the starter.
    that stud needs to be tight all by its self.
  3. #3 Re: battery cable boondoggle!!
    Aug 2011
    new fairfield ct
    cable goes to a stud on the trans. and to the relay box on the wheel well. the lights coming on on the dash is what's making me think I really screwed something!!!
  4. #4 Re: battery cable boondoggle!!
    Aug 2011
    new fairfield ct
    one other thing i do not hear the fuel pump come on when i turn the key does this indicate that i fried the ignition swithch?
  5. #5 Re: battery cable boondoggle!!
    Grand Rapids, MI
    sounds like your grounds aren't right if you get those dummy lights all the time.
    or the battery is low. when it's low retarded things happen.
    edit: wait...are you talking about the starter cables or the battery cables? im confused.
  6. #6 Re: battery cable boondoggle!!
    Aug 2011
    new fairfield ct
    Battery cables. Only one I touched was the positive. battery shows about 12.46 volts. There are two other wires on this same stud if i take the battery cable off the idiot lights go out and the key chime sounds. Cable is brand new from the stealership.
  7. #7 Re: battery cable boondoggle!!
    Grand Rapids, MI
    hmm. so you're sure that you hooked every wire/cable back up exactly the way it was?? there is a ground under the fuse box in that area...make sure you haven't messed up your grounds. did you mess with anything else??
  8. #8 Re: battery cable boondoggle!!
    Aug 2011
    new fairfield ct
    That's what it sounds like a bad connect somewhere. i'll check that ground tomorrow when it's light again. car has remote start and I did break that wire but i don't think thats the prob i spliced it back though.
    Really, only three nuts to do one to the fuse box one on the battery one on the stud. REALLY !!!!
  9. #9 Re: battery cable boondoggle!!
    Aug 2011
    new fairfield ct
    did i fry something if so what do you think is the most likely suspect?
  10. #10 Re: battery cable boondoggle!!
    Florida
    the positive should not be "grounded" to the transmission. the neg battery cable grounds there...
    the positive cable should go from the battery to the starter and on my Z it also goes to the fuse box on the driver side... but the pos is not to be grounded to the engine or trany.
  11. #11 Re: battery cable boondoggle!!
    Grand Rapids, MI
    hmm. the remote start wire breaking things raises an eyebrow. make sure that splice is good and solid. make sure your grounds are on and not corroded. also check ALL fuses just to be sure.
    i dont think you fried anything, just sounds like a bad connection (or no connection) somewhere.
  12. #12 Re: battery cable boondoggle!!
    North Jersey
    idfk what a 'Boondoggle' is.
    but i like it!!
  13. #13 Re: battery cable boondoggle!!
    Grand Rapids, MI
    Quote Originally Posted by jerZcavy4120 View Post
    but i like it!!
    definitely forgot to ask wtf a boondoggle is...got distracted by his problem.
    so wtf is it??
  14. #14 Re: battery cable boondoggle!!
    Aug 2011
    new fairfield ct
    So you think I disconnected the wrong one and now I'm not grounded and it may make sense now. i did not pull the old cable out of the loom so yeah I could have done that bass ackwards!
    Boondoggle is just a clean way of saying major f up!
  15. #15 Re: battery cable boondoggle!!
    Aug 2011
    new fairfield ct
    I think you win the prize must be what i did wrong!!!
  16. #16 Re: battery cable boondoggle!!
    Grand Rapids, MI
    well just go check back over yourself and make sure you have the grounds hooked up properly. i had the transmission ground off in my old GT when we swapped the motor, and i could not for the life of me figure out what it was. and i had the same weird dash light symptoms as you. and it wouldn't do squat. so yeah.
  17. #17 Re: battery cable boondoggle!!
    Aug 2011
    new fairfield ct
    yeah hopefully daylight will shed a new one so to speak!
  18. #18 Re: battery cable boondoggle!!
    when you hooked up the cable, were there a chit load of sparks, like a lot?
    poss cable goes to the starter, neg goes to the trans stud.
    im thinking you got stuff backwards.
  19. #19 Re: battery cable boondoggle!!
    Aug 2011
    new fairfield ct
    Quote Originally Posted by Z34Phoenix View Post
    no not really did spark a little at the battery though first thing i do tomorrow is swap that out. get lazy you get stupid. Think that's what happened here.
  20. #20 Re: battery cable boondoggle!!
    Grand Rapids, MI
    yeah. a little spark is normal when hooking up the battery cables but not huge sparks. i think you just made an error somewhere hooked up the wrong thing or didn't hook up a ground or something.
    oh. and if it aint broke dont fix it....why did you touch it?
  1. Detent cable Help!!
    By Maxwellsilverhammer in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-02-2011, 03:13 AM
  2. Replacing battery cable
    By StFarmer in forum General Tech Discussion
    Last Post: 07-28-2010, 07:45 PM
  3. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
  4. run the power cable from battery to trunk - FINISHED!! PICS!
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 03-19-2009, 04:17 PM
