Thread: battery cable boondoggle!!
Results 1 to 20 of 27
  1. #1 Re: battery cable boondoggle!!
    Grand Rapids, MI
    sounds like your grounds aren't right if you get those dummy lights all the time.
    or the battery is low. when it's low retarded things happen.
    edit: wait...are you talking about the starter cables or the battery cables? im confused.
  2. #2 Re: battery cable boondoggle!!
    Donating Users falconjohnd's Avatar
    Aug 2011
    new fairfield ct
    Battery cables. Only one I touched was the positive. battery shows about 12.46 volts. There are two other wires on this same stud if i take the battery cable off the idiot lights go out and the key chime sounds. Cable is brand new from the stealership.
  1. Detent cable Help!!
    By Maxwellsilverhammer in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-02-2011, 03:13 AM
  2. Replacing battery cable
    By StFarmer in forum General Tech Discussion
    Last Post: 07-28-2010, 07:45 PM
  3. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
  4. run the power cable from battery to trunk - FINISHED!! PICS!
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 03-19-2009, 04:17 PM
