TPS can be adjusted.
i accidentally said IAC.
Tried plugging in a scanner to see if something's out of place (besides the idle)?
I reset the pcm tonight after cleaning the pcv to eliminate that as the cause and now the SES light is on. I'm relieved because now that might help figure out the issue.. going to find out what code is showing tomorrow.. will update.
It's quite possible you put the TPS on incorrectly. There is a way to mess it up.
Scanner would help tremendously. And..I doubt things keep happening. Likely it's something you touched.. (just saying, been there..done that)
