Thread: High idle in every gear
Results 1 to 19 of 19
  1. #1 Re: High idle in every gear
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Come on.... Anybody?
  2. #2 Re: High idle in every gear
    Pennsylvania
    Tried plugging in a scanner to see if something's out of place (besides the idle)?
  3. #3 Re: High idle in every gear
    Oct 2011
    Reading PA
    I reset the pcm tonight after cleaning the pcv to eliminate that as the cause and now the SES light is on. I'm relieved because now that might help figure out the issue.. going to find out what code is showing tomorrow.. will update.
  4. #4 Re: High idle in every gear
    It's quite possible you put the TPS on incorrectly. There is a way to mess it up.
    Scanner would help tremendously. And..I doubt things keep happening. Likely it's something you touched.. (just saying, been there..done that)
  5. #5 Re: High idle in every gear
    Oct 2011
    Reading PA
    Jesus.. have some faith.. its not the tps!!! Codes were for egr valve.. taking it off and cleaning it real good shortly.
  6. #6 Re: High idle in every gear
    I have faith....that often it's the last thing we messed with that causes the issue that pops up suddenly afterward.
    I was naive at one point in my life. Then I became experienced, you'll find much of my diagnosis starts with .."What have you recently done?" lol
    Which EGR code?
  7. #7 Re: High idle in every gear
    Plus..you know a bad tps or incorrectly installed...would high idle ya.
  1. Clatter At Idle in Gear
    By brandonl2000 in forum General Tech Discussion
    Last Post: 04-06-2011, 06:00 PM
  2. Need help with my high idle
    By GPMANE97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 09:11 PM
  3. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. fast high low idle
    By gtchris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 04:17 PM
