Thread: Power Window Question
Results 1 to 15 of 15
  1. #1 Re: Power Window Question
    i had both my gmc trucks door regulators replaced 2 times by the dealer, after the warranty the pass side went out again, the ebay one out lasted the dealer one.
    i had manual windows but the mechanics are all the same. the cable fails, or the plastic rollers fail and eat the cable.
  2. #2 Re: Power Window Question
    You guy know.. the biggest issue is probably lack of lube and then the ball pulls through the plastic. Bonne guys have made up metal to put in there. I'm thinking I might figure it out for W bodies.
  3. #3 Re: Power Window Question
    i used to spray everything down best i could with anything wd-40 to silicone spray, then switched to graphite spray for locks, that stuff is slick. and works well.
  4. #4 Re: Power Window Question
    SE Level Member Bologna's Avatar
    Oct 2011
    Illinois
    I've got some silicone spray that I used on my Jeep that worked really well. I plan on lubing it up really good before using it.
    And the junkyard might be better but then again it is used and you can't predict how long it would last.
  5. #5 Re: Power Window Question
    Denver
    I put one of the cheapie window regulators (from RockAuto) in mine. It lasted about 8 months.
    I've sinced replaced witha Dorman from Checker and it's basically the same as OEM whereas the cheapie had a plastic return pully assembly.
    The cheapo you got from ebay will work, for a little while. When it breaks (it will break), replaced it with a good one.
    The Dorman from Checker has a lifetime warranty.
  6. #6 Re: Power Window Question
    Oct 2011
    Illinois
    Quote Originally Posted by SJAndrew View Post
    Alright, I will keep that in mind. Thanks
  7. #7 Re: Power Window Question
    GTP Level Member 1ATony's Avatar
    mass
    We carry a pretty good selection of window regulators for these cars. Here's a link to them on our site if anyone would like to check on pricing.
    Grand Prix Window Regulator
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  8. #8 Re: Power Window Question
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Let me know if you need help with drawings or getting some pieces made. I can probably help.
    I'm not crazy about the aftermarket ones either, no matter the cost. After comparing the operation of a new OEM part to a +$130 aftermarket part, I'll never buy aftermarket on one of these again.
  1. power window question
    By mngtp in forum General Tech Discussion
    Last Post: 08-08-2011, 08:09 AM
  2. One power window out
    By andante147 in forum General Tech Discussion
    Last Post: 04-26-2011, 02:33 PM
  3. Power window question
    By adurn in forum Audio, Security & Visual Electronics
    Last Post: 03-26-2011, 01:00 PM
  4. Power window stumper
    By pbrumfield2007 in forum Introductions/Noob Questions
    Last Post: 08-12-2009, 11:25 AM
  5. power window slash electrical question
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 06-22-2008, 09:25 PM
