Question stated in a simple way: Would it be easier to replace only the window motor or would it be easier to replace the whole assembly?
My window only rolls up and down sometimes when I push the button. I took the door panel off and took the switch off and put paper clips in the dark blue and brown wire slots and then hooked up 12 volts to it to make sure it wasn't the switch and it still didn't work. So I believe that it's the motor and I was just wondering if I should buy only the motor or would it be really hard to just replace the motor? I plan on going to the local junkyard to pick up the part.
Thanks,
Kyle
Car: 1997 Pontiac Grand Prix GTP 2 door coupe
