Thread: Troubleshooting ABS/Trac Control off
Results 1 to 8 of 8
  1. #1 Re: Troubleshooting ABS/Trac Control off
    Nov 2011
    USA
    Quote Originally Posted by apok View Post
    Ended up unplugging the abs connector and cleaning out both heads. Haven't had a problem since
    I think I am having the same issue. Only my ABS/Trac Off light comes on if I make a sharp right turn. So I am thinking it is a connection/wiring issue. If I drive start or make no sharp turns the light does not come on.
    How do you get to these sensors to clean them?
    Also, took it to OReilly auto parts to borrow their scanner to see if it threw a code and no codes come up. Maybe their scanner can't read ABS codes?
    This is on a 2002 Grand Prix SE - 3.1 liter FWD.
  2. #2 Re: Troubleshooting ABS/Trac Control off
    Sep 2011
    Ontario, Canada
    Quote Originally Posted by duketter View Post
    I just unplugged the connector from the wheel hub, and wiped it down with a clean microfiber cloth. Compressed air may help as well.
    I found a TSB described here that might help you as well. Good luck!
    I had issues reading the codes once the vehicle is restarted.. they seem to clear quickly.
  1. ABS Trac control light came on Another one ):
    By sdeters in forum Brakes/Suspension/Chassis
    Last Post: 09-16-2011, 06:18 AM
  2. 04 GTP Trac control
    By reddog in forum Brakes/Suspension/Chassis
    Last Post: 09-07-2010, 12:13 PM
  3. ABS and Trac Control Lights On
    By itfrg in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2010, 03:07 PM
  4. trac control firing off
    By 04muscle in forum General Tech Discussion
    Last Post: 09-05-2009, 04:01 PM
  5. trac control
    By mileyguard in forum General Tech Discussion
    Last Post: 03-24-2009, 12:02 PM
