Thread: ABS and Trac Control Lights On
Results 1 to 5 of 5
  1. #1 ABS and Trac Control Lights On
    Feb 2010
    nj
    I have a 1999 Pontiac Grand Prix. Today the ABS and Trac Control lights came on. I tried shutting off the engine and have them reset. When I started the engine the lights were off. Once I started moving, the lights came on within a quarter of a mile.
    Any ideas?
    Thanks
  2. #2 Re: ABS and Trac Control Lights On
    Joliet, IL
    bad bearing.....or bad EBTCM(ABS module)....i have the same problem and i think its my EBTCM as i replaced both front bearing and they are still on.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  3. #3 Re: ABS and Trac Control Lights On
    Windsor (ON) Canada
    ^ what he said...If it's just a hub assembly, your looking at about $150-200 worth or repairs (cost me that much after new hub and tools)
    Wheel Bearing Hub Assembly Replacement Guide - General Motors Pontiac Grand Prix GTP - Pictures & Instructions
  4. #4 Re: ABS and Trac Control Lights On
    IL
    Had the same problem - replaced both hubs one was growling anyway still had intermittant abs/tcs - after closer look found Bubba had spliced the abs wiring in two spots with a twist and tape. I re-did the slpice with solder/heat shrink Lights have been off over a month now.
  5. #5 Re: ABS and Trac Control Lights On
    Donating Users
    South Deerfield, MA
    You can't rule out a bad rear hub either. I've had a rear hub fail and cause the same problem. Best to have somebody scan it with a scanner that will read ABS codes. Standard OBDII scanners will not read ABS codes.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. trac control firing off
    By 04muscle in forum General Tech Discussion
    Last Post: 09-05-2009, 04:01 PM
  2. Hit pothole..now ABS and TRAC OFF lights stay on
    By abuckley1290 in forum General Tech Discussion
    Last Post: 06-15-2009, 11:07 PM
  3. trac control
    By mileyguard in forum General Tech Discussion
    Last Post: 03-24-2009, 12:02 PM
  4. ABS and trac off lights
    By probuilder1 in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 06:31 AM
  5. '99 GT - ABS/Traction Control Lights
    By Sparg93 in forum General Tech Discussion
    Last Post: 01-15-2009, 06:21 PM
