Thread: Header Vibration in Reverse
Results 1 to 10 of 10
  1. #1 Re: Header Vibration in Reverse
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    Quote Originally Posted by brandonl2000 View Post
    well the engine shifts one way or the other depending if its in R or D. so in one gear it may push up one part of the dp one way or another to make the o2 hit the firewall or the dp to hit the flex. my bet is one of those two just gotta get under the car and find it.
    my suggestion. ngk o2 sensor is shorter according to Matt. so might could try that. and you could also try new lower mounts if you haven't done those and you can try flipping your dogbones if you haven't already to hold things still.
    Yea i got all poly uppers
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  2. #2 Re: Header Vibration in Reverse
    mine does the same, because the o2 smacks the firewall/tunnel.
    You can get under there with a big ass hammer and beat the **** out of that area if you want to, or take a air hammer and beat the **** of it and make more room.
    Or just leave it the way it is, thats what I did.
  1. Weak reverse
    By nj346 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-26-2011, 09:38 PM
  2. header gasket - header clamps - kn filter
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-21-2011, 10:00 AM
  3. freakin reverse
    By gotboost3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-11-2009, 03:20 PM
  4. reverse
    Last Post: 01-07-2009, 11:23 AM
  5. Bad vibration after header install
    By Smokin2000gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 09:08 PM
