Thread: Bad vibration after header install
Results 1 to 20 of 20
  1. #1 Bad vibration after header install
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Ok well I finally got my headers installed and I went to take it out for a little test drive today and as soon as I started it up it began vibrating pretty bad. The vibrations were so bad that I didn't gas it over half throttle for fear of breaking something. There is also a rattling noise which sounds like it's either coming from the cat or the heatshield above it. Could the cat hitting the heat shielding actually cause such a bad vibration? Another thing I noticed is that the front O2 is resting on two unknown metal lines, but idk if that's the cause of the vibration either. I would jack it up and check out what's going on underneath but it's raining/snowing out.
    Anyone have any ideas? I swear I have the worst luck with cars .
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  2. #2 Re: Bad vibration after header install
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    not sure....did u check and make sure u have everything locked down tight.. i know i left one of my motor mounts hanging off i ( luckily noticed b4 i started it up) ..i would just doublt check everything.....and dont worry after i installed my headers and my exhaust my car sat for 2 weeks b4 i could drive it because i ripped a vacume hose and couldnt figure out y my car was running like shiot...
    180 t-stat, wizaired cai, s&s headers, 3inch cat back exhaust,jpg plug wires, auto lite plugs, 3.4 pulley, and ovk pcm......rockers to come............next summer might go intercooled
  3. #3 Re: Bad vibration after header install
    Jul 2008
    Dekalb, IL
    Yep everything is torqued down tight.
  4. #4 Re: Bad vibration after header install
    Jul 2008
    Dekalb, IL
    The fins from the cat are kinda close to the heatshield, but if it was from that hitting would it really make my car vibrate as bad as it is?
  5. #5 Re: Bad vibration after header install
    Feb 2008
    newyork
    hmmmm ....... i got the same headers and i just did them about a month ago......i dont see y it would be vibrating.... all i know is for me it was a vacume hose the size of a tooth pick and it made my car run real crappy to the point were i didnt drive it or start it up for 2 weeks....idk im sure someone else will give u some better answer so just wait till tonight when everyones on lol
  6. #6 Re: Bad vibration after header install
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by kingd44 View Post
    Lol same thing happened to me. Did it happen to be the one that plugs into the underside of that thing on the back fuel rail ?
  7. #7 Re: Bad vibration after header install
    not quite sure, but im pretty sure that it doesnt hit anything. what metal lines are you speaking of? trans fluid lines?
  8. #8 Re: Bad vibration after header install
    Jul 2008
    Dekalb, IL
    I'll try and take a pic.
  9. #9 Re: Bad vibration after header install
    Jul 2008
    Dekalb, IL
    Well the vibration is definitely from the O2 sensor resting on those two lines as it doesn't vibrate when I put it in reverse which lifts the O2 sensor up and away from those lines. So what am I supposed to do about this? Here's a pic.
  10. #10 Re: Bad vibration after header install
    Feb 2008
    newyork
    the way mine sits....im just touching my transmission stick to the right but im above the metal lines on the bottom by a good 3/4" idk y mine would be positioned differently do u bio?
  11. #11 Re: Bad vibration after header install
    Barksdale AFB, LA
    That looks like power steering lines...
    If so, do whatever you have to do to keep the O2 sensor off them. Power steering fluid is flammable and the O2 sensor gets VERY hot.
    2009 Subaru Impreza WRX STI
  12. #12 Re: Bad vibration after header install
    my headers are touching the heat shield on my front fans. nothing bad has happened yet.
    i use shorter dogbones as well.
  13. #13 Re: Bad vibration after header install
    Jul 2008
    Dekalb, IL
    Yep the shorter dogbones cured my problems, it did melt the fan shroud a little bit, but whatever it's not like I care about that hunk of plastic anyway. Now I just gotta get my cat to stop rattling up against the heatshield grrr... oh well at least I'm able to go wot now, and let me tell ya I love it . Now it's time to start dialing in the tune.
  14. #14 Re: Bad vibration after header install
    Feb 2008
    newyork
    i still cant go wot wtf!!!!!!!!
  1. vibration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:24 AM
  2. 01 GT Vibration in Front Right End
    By sweard2003 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 08:57 AM
  3. 01 GP gt bad vibration when cornering right
    By 01RedfireGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2008, 05:28 PM
  4. Please help with Vibration Problem
    By John_Shughart in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2008, 09:57 PM
  5. Step by Step header install.. HELP!!!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:51 PM
