Thread: Cyl 5 misfire. Tried everything
Results 1 to 4 of 4
  1. #1 Cyl 5 misfire. Tried everything
    Acworth, Georgia
    Ok some of you have seen my other threads but here's an update.
    Cyl 5 misfire, injector 5 control circuit (something like that). Found some wires that are burnt to **** running behind the engine. Got burnt on the rear mani. Looks like they run to the rear o2 and into the transmission but up top they are running along with the injector wires. Checked voltage on injector, good. Ohmed out the injector and it's good. Compressions good. Changed out the ignition control module, coils, spark plug and plug wire and still nothing. Strong smell of gas comming from the exhaust. Swapped around injectors no change. Any other ideas will help out alot thanks guys.
  2. #2 Re: Cyl 5 misfire. Tried everything
    Minnesota
    Did you check/replace the plugs?
    What exact codes are you getting?
  3. #3 Re: Cyl 5 misfire. Tried everything
    Acworth, Georgia
    Replaced the plug. Spark looks good.
    P0205
    P0300
    P0305
    P0138
    P0141
    I think that's all of them. I don't have a new scan with me right now but I think that's all I have.
  4. #4 Re: Cyl 5 misfire. Tried everything
    Please google and list the names for all those codes.
  1. Maybe a misfire?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2010, 04:24 PM
  2. Very Bad Misfire
    By SDGTP99 in forum General Tech Discussion
    Last Post: 05-12-2010, 09:17 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Need help with misfire 98 gtp!
    By Viperhunter in forum General Tech Discussion
    Last Post: 10-08-2009, 02:39 PM
  5. Misfire
    By munkee in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-12-2009, 06:46 PM
