Thread: Stutter when cold
Results 1 to 5 of 5
  1. #1 Stutter when cold
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    Most mornings my car has problems accelerating when it is cold. It like stutters and almost killed itself the other morning.
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  2. #2 Re: Stutter when cold
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    any codes?
  3. #3 Re: Stutter when cold
    Apr 2011
    Fargo
    Guess I could go check tommorrow
  4. #4 Re: Stutter when cold
    its because its not warmed up all the way and still in closed loop, so its already runnin rich and you give it gas and it comes close to flooding and acts like it wants to die,
    SMGPFC Member #10
  5. #5 Re: Stutter when cold
    let it idle till you can tap the gas and the high idle goes away, then drive the car normally. by normal i mean not like a race car.
    jumping on any engine when its cold is a bad idea, and good way to break stuff.
    i let any engine warm up some, even a lawn mower or a weed whacker.
    the oil is also "all" in the pan, aka dry start, cold oil don't pump as well as warm or hot oil does.
    be kind to your car and let it idle for at least 2 to 3 minutes in the mornings (longer in the winter) or any time its been sitting for hours and is cold.
  1. weird stutter after 1.8 rr install
    By reallyfast1 in forum General Tech Discussion
    Last Post: 07-21-2011, 04:34 PM
  2. 05 GTP Comp G Engine Stutter
    By mrnodaysoff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2011, 08:22 AM
  3. Heavy stutter under boost, but no mis-fires
    By 007 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 12:46 AM
  4. 2000 SE 3.1L engine stutter
    By ejstark in forum General Tech Discussion
    Last Post: 06-30-2009, 01:03 PM
  5. Engine stutter apon downshift?
    By Bogers99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2008, 02:58 PM
