Thread: FWI cause rich/lean???
Results 1 to 10 of 10
  1. #1 FWI cause rich/lean???
    Wichita
    I just put on a JMB FWI yesterday. It looks great, makes the s/c whine a bit louder. problem is not long after I put it on the engine light came on and I got code P0171 & P0172. Rich & lean codes.
  2. #2 Re: FWI cause rich/lean???
    Jun 2011
    Detroit, MI
    You might need to get it tuned
    iLoveSpade
  3. #3 Re: FWI cause rich/lean???
    Those are vacuum leak codes, breh.
    Nothing to do with your JMB intake.
  4. #4 Re: FWI cause rich/lean???
    Wichita
    I find it odd to get vacuum leak codes out of the blue when I haven't messed with any lines recently. Just sayin.
  5. #5 Re: FWI cause rich/lean???
    Well, breh I don't know what to tell you that is what the codes are....
  6. #6 Re: FWI cause rich/lean???
    Wichita
    I'll take yer advice n check fer leaks.
  7. #7 Re: FWI cause rich/lean???
    Well I mean I understand where your coming from...just by swapping intakes I don't see how there WOULD be any issue...clear them and see if they come back?
  8. #8 Re: FWI cause rich/lean???
    Wichita
    I cleared em n code p0171 came back
  9. #9 Re: FWI cause rich/lean???
    Whelp then there is a leak somwhere...did you check with carb cleaner? Sprayin' it around?
  10. #10 Re: FWI cause rich/lean???
    Wichita
    And there was a leak somewhere. Sprayed carb cleaner and found leaks at injector's 3 & 5 & of course the pcv notch. Turns out the O-rings on those injectors were chewed up bad. That explains the missfires.
  1. ok what is going on???? lean or rich?
    By jj7ski in forum General Tech Discussion
    Last Post: 01-06-2011, 10:11 PM
  2. rich idle, lean when high rpm and knock?
    By copperpacecar in forum General Tech Discussion
    Last Post: 07-30-2010, 03:24 PM
  3. Rich vs Lean
    By 02blackgpgt in forum General Tech Discussion
    Last Post: 05-23-2010, 11:39 AM
  4. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
