Thread: Rich vs Lean
Results 1 to 12 of 12
  1. #1 Rich vs Lean
    GT Level Member 02blackgpgt's Avatar
    Jan 2009
    Kennesaw, GA
    Ok so my MAF sensor has gone out and i dont have the money to replace it. With it plugged in it is running lean and trying to die when i crank it. When i unplug it it is running rich and seems to run better. My question is: I am driving down to Florida tomorrow from Georgia. Will it be better to unplug it and run rich or leave it plugged up and run lean? What are the pros/cons of each?
    if it wasnt an automatic front wheel drive four door grandmas car it would be really nice
    Mods?? What the f#ck is a mod??
  2. #2 Re: Rich vs Lean
    Jul 2008
    sumter,south carolina
    i would think running rich is better then lean.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Rich vs Lean
    Jan 2009
    Kennesaw, GA
    I was thinking the same thing but Im no mechanic so I figured there was probably something I didnt think about so I would just ask.
  4. #4 Re: Rich vs Lean
    GTX Level Member cerick08GP's Avatar
    Well let me put it this way, running lean might burn a hole in a piston or two. And running rich will probably only result in bad mpg. It is a tough choice you’ll have to deal with.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: Rich vs Lean
    Wichita
    Go to a local salvage yard & see if you cant get a new MAF.
  6. #6 Re: Rich vs Lean
    Delaware, OH
    best bet is to let it run rich. Sure you'll get worse MPG but the worst I can see happening is you foul out a set of plugs. Running rich you could burn a hole in a piston.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  7. #7 Re: Rich vs Lean
    Jersey
    un-plug it
    16' wrx sti- stock
  8. #8 Re: Rich vs Lean
    Donating Users blowfishRus6's Avatar
    g.a.
    running rich can blow out rings after a while.
    run it rich, its safer for now. change the oil when you get back and get a maf.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  9. #9 Re: Rich vs Lean
    Jan 2009
    Kennesaw, GA
    Quote Originally Posted by cerick08GP View Post
    lol its a tough choice
    Quote Originally Posted by blowfishRus6 View Post
    I changed the oil yesterday. Would I still need to? Why would I need to?
  10. #10 Re: Rich vs Lean
    SE Level Member obsidiansixer's Avatar
    fredericksburg va
    if you can tune your car via hptuners etc, tune it with the PE tables. no need for a silly MAF.
    1997 T70 V6 Camaro
    1998 V6 Firebird
  11. #11 Re: Rich vs Lean
    Quote Originally Posted by benner View Post
    best bet is to let it run rich. Running rich you could burn a hole in a piston.
    Ya lost me
  12. #12 Re: Rich vs Lean
    g.a.
    Quote Originally Posted by 02blackgpgt View Post
    all the unburnt fuel can wash down the cylinder walls and get in your oil.
    over time it will start to cause issues. bearing failure, can wash the oil off the cylinder walls and cause the rings to scuff the walls and possible break rings. lost of compression and potentially chip pistons when/if the rings snap off.
    its slow.
  1. Rich Condition HELP!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2009, 04:51 PM
  2. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  3. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
  4. Rich Neighborhood :D
    By blueguy in forum Visual/Body Modifications
    Last Post: 05-15-2009, 12:06 AM
  5. Car runs rich and surges at an idle?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 02:54 PM
