I just put on a JMB FWI yesterday. It looks great, makes the s/c whine a bit louder. problem is not long after I put it on the engine light came on and I got code P0171 & P0172. Rich & lean codes.
Those are vacuum leak codes, breh.
Nothing to do with your JMB intake.
Well, breh I don't know what to tell you that is what the codes are....
Well I mean I understand where your coming from...just by swapping intakes I don't see how there WOULD be any issue...clear them and see if they come back?
Whelp then there is a leak somwhere...did you check with carb cleaner? Sprayin' it around?
And there was a leak somewhere. Sprayed carb cleaner and found leaks at injector's 3 & 5 & of course the pcv notch. Turns out the O-rings on those injectors were chewed up bad. That explains the missfires.
