Thread: Blew it up :(
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Blew it up :(
    Quote Originally Posted by shawn3091 View Post
    i may just get a low mile l36 bottom since they are fully forged iirc? but then i run into already having my gen 3 intake, ic core and ported sc that i hate to have to sell and get a new ic core, intake and sc. how would bolting my current intake, core and sc work? will my l67 intake even bolt onto l36 heads?
    Not forged, but strong motor at least
    L36 and L67 bottom ends are identical except for the pistons, L36 has higher compression setup.
    Take L36 bottom, strap on l67 heads and all the other stuff and your good to role...after a tune of course
  2. #22 Re: Blew it up :(
    I say find an L32 complete and use the gen v setup...
  3. #23 Re: Blew it up :(
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    and i would need to get a different ic core if i decided to just use the gen v? and my xp cam would work fine in a l32 bottom? what about my 105 springs on the l32 heads?
  4. #24 Re: Blew it up :(
    Jan 1970
    Maquoketa, Iowa
    I would get a wideband if you have more than a $1500 worth of mods in an engine or plan on running lower than 13's.
  5. #25 Re: Blew it up :(
    Everything will swap over fine. You can pull the springs and swap them over, you would loose the IC, but really its not that hard to sell it used
    And since you toasted the bottom half of the motor you could pull the top half (heads, LIM, s/c) and sell it as a top swap.
    Between the sale of the used IC and top swap, you can buy another IC for the Gen V
  6. #26 Re: Blew it up :(
    Couple things I commonly see. Ensure there's not crud built up on top of the knock sensor in the coolant passage. Often enough if you pull a knock sensor, you won't have any coolant come out. That's because there's a layer on top of it. This may effect the sensitivity of the sensor.
    Shoot 2003 SSEi a pm. He's right in your area. So far he hasn't blown an engine, only transmissions. For the record...he killed my first one.
  7. #27 Re: Blew it up :(
    Jan 2009
    State College PA
    Quote Originally Posted by DrunkieTheBear View Post
    sounds like a good idea
  8. #28 Re: Blew it up :(
    GTP Level Member
    Pittsburgh
    Hi, sorry to hear you blew up the car, however the ZZP PCM sucks balls.
    I can tune the car for you
    2003 SSEi,
  9. #29 Re: Blew it up :(
    Jan 2009
    State College PA
    it will be a little while before anything happens, i may end up dropping original stock 3800 back in it and selling it, or could sell it as it sits or without a motor and start looking for a f body, really not sure
  10. #30 Re: Blew it up :(
    Topeka, KS
    Y u no have headers ?
  1. blew a head gasket, what next?
    By AlamoGuy in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-07-2011, 07:13 PM
  2. Engine Blew
    By Davisgtp in forum Off Topic Discussion
    Last Post: 07-13-2010, 07:37 PM
  3. blew up Gp AGAIN
    By kaosGP97 in forum The Rant Forum
    Last Post: 08-04-2009, 10:10 PM
  4. air bag blew up!!!
    Last Post: 07-19-2008, 03:35 PM
  5. Blew Away A New Mustang GT 5-Speed
    By jdbaringer in forum Track Sessions and Kills
    Last Post: 06-11-2008, 03:20 PM
