Thread: Sway Bar
Results 1 to 20 of 33
  1. #1 Re: Sway Bar
    Jun 2011
    Detroit, MI
    Quote Originally Posted by Silver GTP View Post
    Guess I'll tell the same lie then. Mine went in from the side in far less than 2 1/2 hours.
    Guess you will, because I was talking about the Dorman, not a hollow tube...
    iLoveSpade
  2. #2 Re: Sway Bar
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by Hippo Machine View Post
    Guess you will, because I was talking about the Dorman, not a flimsy hollow tube...
    lol. So, since they are the same dimensions, are you saying the GMPP bar bends like a rubber band to go in easier? Please elaborate on how your Dorman bar goes in harder than a GMPP bar does.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: Sway Bar
    Denver
    I think he's saying it's way lighter and thus easier to install (similar to how aluminum heads are faster to install than cast heads etc).
    I can say that laying on by back, crouching down, that manhandling the solid Dorman sway brace is not somthing I would like to mess with. With little leverage, so close to the ground, it would be a bastard as it weighs a ton.
  4. #4 Re: Sway Bar
    Jun 2011
    Detroit, MI
    lol. Please elaborate on how your Dorman bar goes in harder than a GMPP bar does.
    Umm a hollow tube is much lighter than a solid tube.
    iLoveSpade
  5. #5 Re: Sway Bar
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by iamsam2010 View Post
    if i replace mine should i go ahead and buy the reinforced one that i keep seeing on slp performance and crap that says its better than stock parts or w/e....i think the dimensions are a little stranger than factory but supposedly better
    not sure
    Probably the best option for you would be the Dorman bar that is being discussed. It is readily available, a cheap price and an upgrade over stock.
    Dorman sway bar 927-100 21.7 lbs. I don't want to discriminate against anybody who's muscularly challenged, but I don't see how that weight would add difficulty to the install.
  6. #6 Re: Sway Bar
    Jun 2011
    Detroit, MI
    When you are trying to manipulate a 20lb bar thats like 4 feet long and isn't straight it can be tough...
    iLoveSpade
  7. #7 Re: Sway Bar
    Use your man arms....MAN.
  8. #8 Re: Sway Bar
    Jun 2011
    Detroit, MI
    All I said is that it isn't easy, and this guy keeps going on about it...
    iLoveSpade
  9. #9 Re: Sway Bar
    Ocala, FL
    Maybe you need to bench press with it for a few weeks before you install it?
  1. Sway bar
    By BuckyKatt in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2010, 09:24 PM
  2. sway bar
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 02:38 PM
  3. Sway bar Help
    By Fivefingerdeathpunch in forum Introductions/Noob Questions
    Last Post: 09-24-2009, 03:40 PM
  4. Sway bar?
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 06:11 PM
  5. sway bar.
    By justwhisen in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2008, 02:53 AM
