Thread: Sway bar
Results 1 to 8 of 8
  1. #1 Sway bar
    South Jersey
    So, the 1999 Grand Prix GTP appears to have one end of the front sway bar cracked. The Haynes manual indicates to replace the bar, you have to drop the subframe. Is this the case or is it possible to get the bar in/out without dropping the subframe?
    Dorman has a sway bar kit that includes everything... according to the various auto part websites its a fit for the GTP... Is it really?
    Thanks in advance.
    BK
  2. #2 Re: Sway bar
    go here.: GM Parts Direct: Your direct source for Genuine GM Parts
    and type this in at on the seach bar: 12498643
    that is the sway bar, its cheap and it works.
  3. #3 Re: Sway bar
    Top Swap in Progress bigtom9492's Avatar
    Dutchess county
    ZZ Performance
    just another option.. if you replace the front... do the back... you will thank me later.
  4. #4 Re: Sway bar
    South Jersey
    Do you suppose that a local dealer would have it in stock at even twice that price?
    Time is a factor here, the car needs to be fixed by the end of the week and will be going to live far away for a long time.
    I've feeling any sway bar is better than a broken one... I'm also concerned about running into complications dropping the subframe.
  5. #5 Re: Sway bar
    Donating Users
    South Deerfield, MA
    I swapped my stock sway bar out for a GMPP one and didn't have to lower the cradle. It will come out.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  6. #6 Re: Sway bar
    Topeka, KS
    You don't have to drop the subframe. It's just easier if your do. Taking out\off the old swaybar is tons easier than putting it back in.
    Take off both front wheels and undo the 4 15mm bolts on top of the cradle, undo both the bolts on the A Arm. Take out sway bar, replace in opposite order. Use anti sease on the bolts on the cradle. They are a ***** otherwise.
  7. #7 Re: Sway bar
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by BuckyKatt View Post
    No, GM parts direct will always be cheaper.
    Thats why is says GM List price.
    You dont have to drop the sub-frame to swap. Taking of one tie will make easier to install, but you do not have to drop the sub frame.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  8. #8 Re: Sway bar
    Charles City, IA
    The dorman bars are a lot better than stock, yes they have a kit with new bushings links and hardware. That is how we always do them at work.
    SMGPFC Two Nipple General
  1. How to get sway bar out
    By basballny2 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2010, 10:37 AM
  2. sway bar
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 02:38 PM
  3. Sway bar Help
    By Fivefingerdeathpunch in forum Introductions/Noob Questions
    Last Post: 09-24-2009, 03:40 PM
  4. sway bar.
    By justwhisen in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2008, 02:53 AM
