Thread: Sway Bar
Results 1 to 20 of 33
  1. #1 Re: Sway Bar
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by Hippo Machine View Post
    Thats a lie, you can't just "slide it in"...
    Guess I'll tell the same lie then. Mine went in from the side in far less than 2 1/2 hours.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: Sway Bar
    Jun 2011
    Detroit, MI
    Quote Originally Posted by Silver GTP View Post
    Guess you will, because I was talking about the Dorman, not a hollow tube...
    iLoveSpade
  3. #3 Re: Sway Bar
    Donating Users
    South Deerfield, MA
    Guess you will, because I was talking about the Dorman, not a flimsy hollow tube...
    lol. So, since they are the same dimensions, are you saying the GMPP bar bends like a rubber band to go in easier? Please elaborate on how your Dorman bar goes in harder than a GMPP bar does.
  4. #4 Re: Sway Bar
    Denver
    I think he's saying it's way lighter and thus easier to install (similar to how aluminum heads are faster to install than cast heads etc).
    I can say that laying on by back, crouching down, that manhandling the solid Dorman sway brace is not somthing I would like to mess with. With little leverage, so close to the ground, it would be a bastard as it weighs a ton.
  5. #5 Re: Sway Bar
    Jun 2011
    Detroit, MI
    lol. Please elaborate on how your Dorman bar goes in harder than a GMPP bar does.
    Umm a hollow tube is much lighter than a solid tube.
    iLoveSpade
  6. #6 Re: Sway Bar
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by iamsam2010 View Post
    if i replace mine should i go ahead and buy the reinforced one that i keep seeing on slp performance and crap that says its better than stock parts or w/e....i think the dimensions are a little stranger than factory but supposedly better
    not sure
    Probably the best option for you would be the Dorman bar that is being discussed. It is readily available, a cheap price and an upgrade over stock.
    Dorman sway bar 927-100 21.7 lbs. I don't want to discriminate against anybody who's muscularly challenged, but I don't see how that weight would add difficulty to the install.
  7. #7 Re: Sway Bar
    Jun 2011
    Detroit, MI
    When you are trying to manipulate a 20lb bar thats like 4 feet long and isn't straight it can be tough...
    iLoveSpade
  8. #8 Re: Sway Bar
    Use your man arms....MAN.
  9. #9 Re: Sway Bar
    Ocala, FL
    Maybe you need to bench press with it for a few weeks before you install it?
  1. Sway bar
    By BuckyKatt in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2010, 09:24 PM
  2. sway bar
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 02:38 PM
  3. Sway bar Help
    By Fivefingerdeathpunch in forum Introductions/Noob Questions
    Last Post: 09-24-2009, 03:40 PM
  4. Sway bar?
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 06:11 PM
  5. sway bar.
    By justwhisen in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2008, 02:53 AM
