Thread: Car seems slow in second gear..vids....and an update...sort of.
Page 1 of 3 123 LastLast
Results 1 to 20 of 59
  1. #1 Car seems slow in second gear..vids....and an update...sort of.
    Never Never Land
    Ok so Brandon and I have been talkin and I kept tellin him my car seems slower than other GTP's. We both took vids to compare and both agree that my car seems slower in second but pulls the same in first gear.
    Here's my vid. My car is a 97 and is bone stock down to the paper air filter with 130K. Regular maintenace has been done and I did a pan drop about 10K ago. I don't have any codes etc etc.
    Brandon's vid. He has an 03 at 103K and I believe he's had regular maintenance as well, pan drop too. Has an intake but that's it.
    Just looking for other's opinions.
    Oh and eff you photobucket for reducing the video quality.
    Something to take note of is before I did my pan drop I had the sloppy second gear shift. I can still make it do it if I time it right but it doesn't do it on it's own anymore. I also have the delayed reverse engagement common to the sloppy second gear shift. I've read these are a result of some sleeve or something getting worn and bleeding off pressure. I wonder if this is my problem.
    I also broke out a stopwatch and did 45-65 times. Mine tend to be 3.7-3.8 seconds while Brandon's is 3.2-3.3 seconds....roughly half a second quicker
    UPDATE/EDIT: Ok so....i've learned that the sloppy second gear shift I have sometimes is also related to the delayed reverse engagement I have. I made a video trying to show this but it's hard to catch it due to not being able to rev very high to really show the lag. I did my best though. Basically I revved to 1500 RPMS and went to reverse. When it drops to 1000 is when it engages. I didn't vary the throttle AT ALL. It was reverse engaging that caused the RPMS to drop.
    So here's the video...also ignore when I said "im gonna go straight to netural" or something to that effect..i meant reverse lol.
    And if you're Clean
    c5cc7a55.mp4 video by 4THGENCAMAROFAN - Photobucket
    Now for some more blabbing. I read on wbodystore.com that the sloppy second gear and delayed reverse gear are a result of the boost valve wearing away at the boost sleeve in the trans causing pressure to bleed off thus causing the stumbling and delayed engagement of the gears...linky..
    W Body Store
    Now for my question...has anybody tried that fix? I may try that in conjunction with a shift kit to see if this will fix my problem. Looking for opinions here as well as personal experience with the boost valve and sleeve kit that wbodystore sells. Not too worried about shift kits ATM but i'll get there.
  2. #2 Re: Car seems slow in second gear..vids.
    Banned
    Mansfield, Ohio
    Dang videos no worky for me wth.....
  3. #3 Re: Car seems slow in second gear..vids.
    My car is a 97
    Found your prollum.
    My rough count is ~4 seconds from the 1-2 shift to 65 mph for both videos.
  4. #4 Re: Car seems slow in second gear..vids.
    Grand Rapids, MI
    Quote Originally Posted by cleangtp View Post
    might try holding CTRL+ALT as you click on the vid. had to do that here at the school house to get em to open
  5. #5 Re: Car seems slow in second gear..vids.
    Never Never Land
    Videos work fine for me clean.
  6. #6 Re: Car seems slow in second gear..vids.
  7. #7 Re: Car seems slow in second gear..vids.
    Never Never Land
    I'd also just like to point out that it seems like Brandon's shifts at a little bit higher RPM. At leat it looks like it to me.
  8. #8 Re: Car seems slow in second gear..vids.
    Banned
    Mansfield, Ohio
    Yes I got them to work..... like I said in chat you foos need a pcm like meowww.... your cars shift at like 5g's lol looked pretty much the same to me.... brandons pulls maybe a tad harder
  9. #9 Re: Car seems slow in second gear..vids.
    Grand Rapids, MI
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    did you give it WOT this go round??
    and just throwing this out there. does it matter that I was about 5mph higher than austin at the time of WOT?
  10. #10 Re: Car seems slow in second gear..vids.
    Never Never Land
    Yes I went WOT in that run. WOT with perf shift on.
  11. #11 Re: Car seems slow in second gear..vids.
    Grand Rapids, MI
    well idk bruh. after all you do bench press double my weight. so my car might have slight weight reduction? lolz.
    and it is a 97...it's weird.
  12. #12 Re: Car seems slow in second gear..vids.
    Never Never Land
    Quote Originally Posted by brandonl2000 View Post
    I wish I could bench double your weight..but anywho..quit pickin on meh damn 97...i like purple. 97 was the only year for purple!!!!
  13. #13 Re: Car seems slow in second gear..vids.
    Banned
    Mansfield, Ohio
    3:30 am in town... 25 mph zone so that's explanation of short wot run.... notice the 6k shift probably doesn't pull any harder than both of your guys car.....
  14. #14 Re: Car seems slow in second gear..vids.
  15. #15 Re: Car seems slow in second gear..vids.
    Grand Rapids, MI
    umm. "tad faster" doesn't cut it. you rockin and rollin there haulin all kinda ass!
  16. #16 Re: Car seems slow in second gear..vids.
    Banned
    Mansfield, Ohio
    Yeah that's pretty quick bet it feels a lot faster driving it than speedo vids makes it look, least that's how mine is....
  17. #17 Re: Car seems slow in second gear..vids.
    Banned
    Mansfield, Ohio
    I also was already rolling 40mph, tad bit quicker from a 30mph mash since it goes from 3rd to 1st....
  18. #18 Re: Car seems slow in second gear..vids.
    Never Never Land
    Someday ill be there Matt.
  19. #19 Re: Car seems slow in second gear..vids.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  20. #20 Re: Car seems slow in second gear..vids.
    Agreed.
    Torque has that effect.
    Quote Originally Posted by 01gpgt01 View Post
    Third is a brick wall? haha.
    Also, what'd you run on that setup?
  1. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  2. new vids
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 06-05-2011, 08:20 PM
  3. GTP vs G8 *vids*
    By Lawngoose in forum Track Sessions and Kills
    Last Post: 10-19-2010, 03:53 PM
  4. More Vids ;)
    By blueguy in forum Track Sessions and Kills
    Last Post: 05-16-2009, 07:25 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
