Thread: Emergency !!!door problem
Results 1 to 7 of 7
  1. #1 Emergency !!!door problem
    Feb 2010
    TN
    Got too work this morning and the door mechanism is jammed in the closed position I can not close the door it will not latch and its raining anyone got a quick fix till I can get home
  2. #2 Re: Emergency !!!door problem
    your talking about the inside of the car door latch closed when the door is still open? if so open the door hold the handle up,as to open it, and with a screw driver or what ever you got to pry the locks open, it should open/pop open.
  3. #3 Re: Emergency !!!door problem
    Chilliwack BC
    Press the unlock button and pull the door handle a bunch of times see if the latch will free up. otherwise grab some garbage bags and some tape
  4. #4 Re: Emergency !!!door problem
    Feb 2010
    TN
    hanks I will try that on my break and let you know. Once i get it home do you think I need a whole new lock or grease this on what is the permanent fix?
  5. #5 Re: Emergency !!!door problem
    Yoga city
    OnLy one way to find out grease then tinker with it
  6. #6 Re: Emergency !!!door problem
    Feb 2010
    TN
    ok well I was wondering what to do with my day off tomorrow guess now I know
  7. #7 Re: Emergency !!!door problem
    Feb 2010
    TN
    OK got it fixed thanks guys
  1. Door problem need Help
    By 96GrandPrix in forum General Tech Discussion
    Last Post: 06-01-2012, 07:26 AM
  2. interior light/door lock/alarm problem
    By nicknitro in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2011, 05:03 PM
  3. Driver side- no heat, blending door problem?
    By suzuki1211 in forum General Tech Discussion
    Last Post: 02-02-2011, 09:32 PM
  4. Auto Door Lock Problem-2000 GTP
    By sandjaso in forum General Tech Discussion
    Last Post: 08-31-2009, 07:25 PM
  5. Power Door Lock Problem-O
    By flynn in forum General Tech Discussion
    Last Post: 12-31-2007, 04:49 PM
