Thread: Auto Door Lock Problem-2000 GTP
Results 1 to 5 of 5
sandjaso Auto Door Lock Problem-2000... 08-28-2009, 12:41 PM
Liquifire Re: Auto Door Lock... 08-28-2009, 02:06 PM
PCTGTP Re: Auto Door Lock... 08-30-2009, 09:58 AM
sandjaso Re: Auto Door Lock... 08-31-2009, 05:28 PM
Liquifire Re: Auto Door Lock... 08-31-2009, 07:25 PM
  1. #1 Auto Door Lock Problem-2000 GTP
    boise
    I have a 2000 GTP. A couple of days ago the auto door lock function quit working. If i put the car into drive the doors do not lock. If I turn the car off the door will not unlock. The door will lock and unlock with the remote and if I use the door switch. Any ideas? Thanks.
  2. #2 Re: Auto Door Lock Problem-2000 GTP
    Wausau, WI
    somehow did you accidentally reprogram this feature. I believe the directions are in the owners manual to active/deactivate this feature
  3. #3 Re: Auto Door Lock Problem-2000 GTP
    Donating Users PCTGTP's Avatar
    Ohio
    might want to check some fuses
  4. #4 Re: Auto Door Lock Problem-2000 GTP
    boise
    Fuses are okay. What is funny is the car will not lock when you put it into drive but when the key is turned off after driving sometimes it will lock and at times do nothing at all. Also, I tried to reprogram the door lock option, however, I could not get the procedure to work? Thanks for helping. Any further ideas?
  5. #5 Re: Auto Door Lock Problem-2000 GTP
    Wausau, WI
    why couldnt you get it to work? which part?
  1. Anti lock braking system problem?
    By knightriider in forum General Tech Discussion
    Last Post: 03-25-2009, 03:59 PM
  2. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
  3. De-rib, De-door ding, and shaved trunk lock and new paint.
    By shavedGPGT in forum Visual/Body Modifications
    Last Post: 11-24-2008, 04:45 PM
  4. Trunk Switch/ Door Unlock and Lock
    By mainecrab in forum General Tech Discussion
    Last Post: 06-02-2008, 08:58 PM
  5. Power Door Lock Problem-O
    By flynn in forum General Tech Discussion
    Last Post: 12-31-2007, 04:49 PM
