Thread: 2004 Grand Prix Front End Clunk - TSBs?
Results 1 to 12 of 12
  1. #1 Re: 2004 Grand Prix Front End Clunk - TSBs?
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    Javi, that link didn't work, can you point me in the right direction to find it on gpona?
    Email all inquiries to willoverkill@gmail.com!
  2. #2 Re: 2004 Grand Prix Front End Clunk - TSBs?
    Aug 2011
    fredericksburg virginia
    i know you said it doesnt feel like a steering shaft clunk but the only tsb i could find is this:
    Subject:Clunk Felt/Noise Heard From Steering Column, Steering Gear and/or Front Of Vehicle During Turning Maneuver and/or Steering Wheel Rotation (Replace Intermediate Shaft As Directed)
    Models:2001-2004 Buick Regal
    2005-2008 Buick Allure (Canada Only), LaCrosse
    2000-2008 Chevrolet Impala
    2000-2007 Chevrolet Monte Carlo
    1998-2002 Oldsmobile Intrigue
    2004-2007 Pontiac Grand Prix
    This bulletin is being revised to add the 2008 Buick LaCrosse/Allure. Please discard Corporate Bulletin Number 01-02-32-001O (Section 02 -- Steering).
    <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2370686&releaseDate=2009-11-25&name=Clunk+Felt%2FNoise+Heard+from+Steering+Col umn%2C+Steering+Gear+and%2For+Front+of+Vehicle+dur ing+Turning+Maneuver+and%2For+Steering+Wheel+Rotat ion+%28Replace+Interme#tab1-2370686">Corrective Action Summary:
    Model Year
    Vehicle Line
    Corrective Action
    2001-2004
    Buick Regal
    Replace using P/N 19179922
    2005-2006
    Buick Allure/LaCrosse
    (built PRIOR to January 1, 2006)
    Replace using P/N 25829292
    2006-2008
    (built AFTER to January 1, 2006)
    Replace using P/N 25828562
    2000-2005
    Chevrolet Impala
    Replace using P/N 19179923
    2006-2008
    Chevrolet Impala
    Replace using P/N 25937479
    2000-2005
    2006-2007
    Replace using P/N 25913680
    1998-2002
    Oldsmobile Intrigue
    2004-2008
    Pontiac Grand Prix
    <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2370686&releaseDate=2009-11-25&name=Clunk+Felt%2FNoise+Heard+from+Steering+Col umn%2C+Steering+Gear+and%2For+Front+of+Vehicle+dur ing+Turning+Maneuver+and%2For+Steering+Wheel+Rotat ion+%28Replace+Interme#ss2-2370686">
    Condition
    Some customers may comment on a clunk type noise coming from the front of the vehicle while driving during a turning maneuver. This condition may also be felt through the steering wheel when the vehicle is stationary and the wheel is rotated from steering stop to steering stop. Some vehicles may only exhibit the noise once for every 360° of wheel rotation. On all other vehicles, this clunk noise will be noticed during low speed acceleration or deceleration, typically in light turns of the steering wheel or when applying/releasing the brakes.
    <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2370686&releaseDate=2009-11-25&name=Clunk+Felt%2FNoise+Heard+from+Steering+Col umn%2C+Steering+Gear+and%2For+Front+of+Vehicle+dur ing+Turning+Maneuver+and%2For+Steering+Wheel+Rotat ion+%28Replace+Interme#ss3-2370686">Cause
    This condition may be caused by a "slip stick" condition of the steering intermediate shaft resulting in the clunk noise or feel through the steering wheel.
    <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2370686&releaseDate=2009-11-25&name=Clunk+Felt%2FNoise+Heard+from+Steering+Col umn%2C+Steering+Gear+and%2For+Front+of+Vehicle+dur ing+Turning+Maneuver+and%2For+Steering+Wheel+Rotat ion+%28Replace+Interme#ss4-2370686">Diagnostic Tip
    Important: This condition is commonly misdiagnosed as originating in the steering gear and has resulted in the replacement of numerous steering gears without correcting the concern.
    Attempt to duplicate the customer's concern and isolate the I-shaft by following the procedure below:
    1. <LI type=1>Locate a large area (parking lot) where the vehicle can be turned in a tight circle. <LI type=1>Turn the steering wheel to the right and/or left all the way to the steering lock, then off the steering lock a 1/4 turn. <LI type=1>Drive the vehicle approximately 5 km/h (3 mph) in a circle, preferably over rough pavement or seams on the road surface. <LI type=1>Drive the vehicle straight ahead at idle speed while applying and releasing the brake pedal. Listen/feel the steering wheel for the clunk/noise condition.
    2. If a clunk is felt in the steering wheel, the MOST likely cause is the I-shaft -- not the steering gear. Continue with the correction.
    <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2370686&releaseDate=2009-11-25&name=Clunk+Felt%2FNoise+Heard+from+Steering+Col umn%2C+Steering+Gear+and%2For+Front+of+Vehicle+dur ing+Turning+Maneuver+and%2For+Steering+Wheel+Rotat ion+%28Replace+Interme#ss5-2370686">Correction
    DO THIS
    DON'T DO THIS
    Replace the intermediate shaft
    DO NOT lube the intermediate shaft.
    Replace the existing intermediate shaft using the service procedure found in Service Information.
    <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2370686&releaseDate=2009-11-25&name=Clunk+Felt%2FNoise+Heard+from+Steering+Col umn%2C+Steering+Gear+and%2For+Front+of+Vehicle+dur ing+Turning+Maneuver+and%2For+Steering+Wheel+Rotat ion+%28Replace+Interme#ss6-2370686">Parts Information
    Part Number
    Description
    19179922
    Shaft -- Steering Gear Coupling
    '01-'04 Buick Regal
    '00-'05 Chev Monte Carlo
    '98-'02 Olds Intrigue
    19179923
    '00-'05 Chev Impala
    25913680
    '06-'07 Chev Monte Carlo
    '04-'08 Pont Grand Prix
    25937479
    '06-'08 Chev Impala
    25829292
    Shaft -- Steering Gear Coupling '05-'06 Buick Allure and LaCrosse vehicles built PRIOR to January 1, 2006
    25828562
    Shaft -- Steering Gear Coupling ’06-'08 Buick Allure and LaCrosse vehicles built AFTER January 1, 2006
  3. #3 Re: 2004 Grand Prix Front End Clunk - TSBs?
    Aug 2011
    well that came out funny :/ anyways that tsb just says replace the steering shaft.
  1. Front End Clunk
    By jcgre3n in forum General Tech Discussion
    Last Post: 03-29-2012, 05:41 PM
  2. Front-End Clunk
    By xerxescct in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2010, 02:25 PM
  3. 2004 grand prix front seats removal
    By ham4864 in forum Visual/Body Modifications
    Last Post: 12-15-2010, 04:35 PM
  4. Clicking coming from front end 2004 Grand Prix
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-02-2010, 05:53 PM
  5. 2004 Grand Prix GT suspension clunk
    By McVaaahhh in forum General Tech Discussion
    Last Post: 04-19-2008, 01:04 PM
