Thread: Mechanic Shop BS or Not? Does a replacement of ig switch means also replacing LOM
Results 1 to 5 of 5
  1. #1 Mechanic Shop BS or Not? Does a replacement of ig switch means also replacing LOM
    Apr 2012
    I know for sure that I need an ignition switch. The symptoms include info center going blank or turning off when I turn the heat on, headlights blinking, heat working when it wants too. A gargage told me that I have to also replace the lock module because of the antithief and get a reprogram at the dealer. Is it necessary for all of this extra work, just to change the ignition switch? email me at cliffordcolvard@yahoo.com thanks
  2. #2 Re: Mechanic Shop BS or Not? Does a replacement of ig switch means also replacing LOM
    Troy OH
    depends on the year of the car, but i've never heard of a lock module. you have to reprogram the anti-theft on the later cars though, yes. probably for some of the 97-03 cars.
  3. #3 Re: Mechanic Shop BS or Not? Does a replacement of ig switch means also replacing LOM
    GTX Level Member blackflag's Avatar
    Virginia
    I have a 2001 and didn't have to do that.
  4. #4 Re: Mechanic Shop BS or Not? Does a replacement of ig switch means also replacing LOM
    Email you? LOL... that's funny
  5. #5 Re: Mechanic Shop BS or Not? Does a replacement of ig switch means also replacing LOM
    Apr 2012
    Thanks for the feedback. I got a 2002 40th anniversary GTP., with all of the bells and whistles
  1. Replacing a dimmer switch on 2008 grand prix
    By cadbob in forum General Tech Discussion
    Last Post: 10-15-2011, 12:19 PM
  2. Replacing ignition switch, can't pull lock cylinder
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2010, 05:46 PM
  3. Ignition Switch Replacement Question
    By r1rider in forum General Tech Discussion
    Last Post: 08-21-2010, 03:27 PM
  4. Can't seem to find out what this code means?
    By oddwraith in forum PCM Tuning
    Last Post: 08-20-2009, 10:06 AM
  5. Ignition Switch Replacement?
    By 02BlueGT in forum General Tech Discussion
    Last Post: 04-06-2008, 08:59 PM
