Thread: 2004 gtp shuts off while accelerating
Results 1 to 5 of 5
trav 2004 gtp shuts off while... 08-30-2011, 12:46 PM
Couch Re: 2004 gtp shuts off while... 08-30-2011, 01:16 PM
Couch Re: 2004 gtp shuts off while... 08-30-2011, 01:19 PM
trav Re: 2004 gtp shuts off while... 08-30-2011, 02:26 PM
Explicit_Spade Re: 2004 gtp shuts off while... 08-30-2011, 04:21 PM
  1. #1 2004 gtp shuts off while accelerating
    Aug 2011
    south carolina
    My 2004 Grand Prix GTP 3.8L shut off today. First the check engine light came on when I was driving at about 50mph. Then when I stepped on it the display said "reduction in power", and shortly thereafter it stalled. It started back up but did the same thing under heavy acceleration. It popped up several codes p0069, p0068, and p2228. Has anyone had the same problem? Thanks.
  2. #2 Re: 2004 gtp shuts off while accelerating
    Chilliwack BC
    Happened to me once. threw no codes though....power reduced sounds like it put itself into limp home mode to protect the motor.
    As far as the codes go...
    p0069 - baro sensor pressure and map sensor pressure difference too low or too high
    p0068 - unexpected throttle posistion and indicated engine load
    p2228 - baro sensor signal voltage low
    so probably a bad connection at the MAP or BARO sensor or faulty MAP or BARO sensor, or an air leak in your intake system (which would explain the p0068)
    these sensors are located at the back of your motor on the other side of the supercharger. but i would check your intake tubing first and make sure there is no leaks.
    if anyone wants to add to this feel free.
    hope this helps. if not...i would have a mechanic have a look at it.
  3. #3 Re: 2004 gtp shuts off while accelerating
    Chilliwack BC
    OH and didn't even realize this was in the introduction section...if ya need help definately post in the general tech discussion more people will notice it there.
    and welcome to the forums ;D
  4. #4 Re: 2004 gtp shuts off while accelerating
    Aug 2011
    south carolina
    Thanks Couch I really appreciate the feedback.
  5. #5 Re: 2004 gtp shuts off while accelerating
    Omaha, NE
    This happened to me at one point... I forgot what the cause was, since I had a lot of issues at the time, but it sucked.
    Good luck, and welcome!
  1. Replies: 21
    Last Post: 08-30-2010, 07:41 PM
  2. Car Shuts Off When Engine Warms Up
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-23-2010, 04:22 PM
  3. just shuts off
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 12:16 AM
  4. Engine shuts down
    By jvee44 in forum General Tech Discussion
    Last Post: 06-23-2009, 01:38 PM
  5. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
