Thread: Engine shuts down
Results 1 to 12 of 12
  1. #1 Engine shuts down
    Maryland
    Vehicle idle for about 10 seconds then it shuts down. I have replaced the fuel pump, inline resistor and the idle control valve and it still shuts down after a few seconds. Can anyone advise?
  2. #2 Re: Engine shuts down
    TDCRacing
    Guest
    Does it start back up after it shuts down? Do you have any codes?
  3. #3 Re: Engine shuts down
    Maryland
    No codes, it starts with no problems it only stays on for about 10 seconds. However, it will at times run for a day or two with no problems and then it starts acting up again. Oh hey thanking for trying to help.
  4. #4 Re: Engine shuts down
    Ohio
    Vacuum leak? Or crank pos sensor?
    00 GTP demodded and forsale
  5. #5 Re: Engine shuts down
    Charles City, IA
    Is your security light flashing?
    SMGPFC Two Nipple General
  6. #6 Re: Engine shuts down
    Jul 2008
    sumter,south carolina
    does the tachometer act funny when this happnens?
    02 GTP with mods 05 GP for DD
  7. #7 Re: Engine shuts down
    Maryland
    No, No security lights. Hey do you think that a clogged exhuast cat converter could also be the problem?
  8. #8 Re: Engine shuts down
    Apr 2009
    Wausau, Wisconsin
    Yeah your car needs to breathe
  9. #9 Re: Engine shuts down
    GTP between the years of '97-'00?
    Probably sounds like this
  10. #10 Re: Engine shuts down
    Maryland
    So I should replace the relay I quess. Thank you gentleman for your assistance this has been very helpfull.
  11. #11 Re: Engine shuts down
    Banned - Busted For Scamming
    Feb 2009
    well that is just the bypass, your fuel pump resistor is bad most likely
  12. #12 Re: Engine shuts down
    Maryland
    Ok, I bend the tab and the car works. However, I have already replaced the inline resistor once. You think I need to get another one or is there a wiring problem.
  1. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
