Thread: Overheated, Low Compression Cyl #3
Results 1 to 3 of 3
Threaded View
  1. #1 Overheated, Low Compression Cyl #3
    SJ PR
    Hi guys,
    Recently my Gran Prix 3.8 Na overheated due to a radiator hole and loss of water. I replaced the radiator and restarted. Started fine but it was shaking more than usual and indicated a misfire on cyl #3 (ses flashed, scanned it). I did a dry compression test and got 180 psi in all except cyl 3 which got 65 psi and cyl 4 got 120. I was planning on removing the heads to inspect the pistons and replace the head gasket.
    1. Any other things i should do while I am there?
    2. I replaced the UIM/LIM in 2007 with the GM aluminum one, should I replace it again? Car was driven only 20k miles in those 4 years.
    3. How hard is to take the rear exhaust manifold with the engine in the car?
    4. Should I go change the rear head gasket or just change the front one?
    5. Where do these metal shavings inside my cooling system come from? My thermostat and housing (pictured) were covered in what appears to be iron shavings. I know the were a result of the overheat because they were not there a month ago. They came off easily with water(they were not baked on).
    Thanks.
  1. Overheated
    By Rather B Blown in forum General Tech Discussion
    Last Post: 07-28-2010, 06:45 AM
  2. Compression Test
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 10:38 PM
  3. compression check
    By justwhisen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2009, 10:09 PM
  4. Compression Check?
    By 99prixgt in forum General Tech Discussion
    Last Post: 06-09-2009, 11:01 AM
  5. Bad Compression?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 01:22 AM
