Thread: Throttle Position Sensor
Results 1 to 8 of 8
apierce1289 Throttle Position Sensor 06-01-2011, 03:46 PM
Wotgtp Re: Throttle Position Sensor 06-01-2011, 04:57 PM
apierce1289 Re: Throttle Position Sensor 06-03-2011, 12:01 AM
DanGTP Re: Throttle Position Sensor 06-01-2011, 06:25 PM
BillBoost37 Re: Throttle Position Sensor 06-02-2011, 06:32 AM
Wotgtp Re: Throttle Position Sensor 06-05-2011, 01:01 PM
Wotgtp Re: Throttle Position Sensor 06-07-2011, 06:15 PM
darkhorizon Re: Throttle Position Sensor 06-07-2011, 09:00 PM
  1. #1 Throttle Position Sensor
    GTP Level Member apierce1289's Avatar
    United States
    Ok so i just got a SES light finaly so i could get it scanned and figure out whats wrong. Went to Auto Zone for a code scan and my "Throttle Position Sensor" craped out. I can still drive the car fine but i have NO power. So my question is..... #1 is it safe for the engine to be drivin to college and work with out hurting it? #2 Is it something i can do my self? And i need links to the best brand TPS so i wont have it crap out again for a long time
  2. #2 Re: Throttle Position Sensor
    Mullet Member Wotgtp's Avatar
    Connecticut
    Did they tell you what number code you have? I seem to be having TPS issues as well, and my code was PO121.
  3. #3 Re: Throttle Position Sensor
    United States
    Quote Originally Posted by Wotgtp View Post
    Yep I got the same code lmao. Just need to wait till next paycheck
  4. #4 Re: Throttle Position Sensor
    Feb 2008
    Just about any new TPS you pick up from a parts store will be good. They're real easy to replace, too. It just takes a T-20 security Torx and about five minutes of your time. Auto Zone has a lot of lifetime warranty electrical components, now, so you might check them out.
  5. #5 Re: Throttle Position Sensor
    Yeah..this is quick and easy.. Got it done yet?
  6. #6 Re: Throttle Position Sensor
    Connecticut
    Replaced it today. Why the hell did GM put little metal bumps in the head of the hex screw!?!? It was a pita at first, then I realized that taking the TB was easier(I don't have torx bits, just the screwdrivers) and took a small punch and a hammer to the metal centers. Then I took it off with the torx screwdriver. At least now the car is running great again. I was getting worried, I thought the trans was screwed up.
  7. #7 Re: Throttle Position Sensor
    Connecticut
    Wtf the code came back on yesterday. I replaced the sensor, checked the connection, both seem to be good. Do I check the sensor and connection with a volt/ohm meter? If so, what are the readings I should have?
  8. #8 Re: Throttle Position Sensor
    Feb 2009
    flintnasty MI
    did you do a relearn?
    If not, google it.
  1. Throttle Position Sensor Optimization
    By silverstreak in forum How To Write-Ups/Tech Tips
    Last Post: 12-25-2010, 03:06 PM
  2. throttle position sensor
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 11:16 AM
  3. THrottle position sensor
    By xsvtank in forum General Tech Discussion
    Last Post: 11-27-2010, 07:17 PM
  4. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
