Thread: Attaching fittings on washer style bottle...
Results 1 to 10 of 10
  1. #1 Attaching fittings on washer style bottle...
    Moore, Oklahoma
    Hi,
    Trying to attach 3/4" plastic barbs on a washer style bottle. I can't put a nut on the back side since the lid hole ain't big enough. I need something strong to bond the barb to the tank. What would you suggest using? I need something that will take heat, coolent, a little stress from hoses, etc. I was thinking maybe Gorrilla glue, what do yo guys think? Thanks!
    Shawn W. Larsen
  2. #2 Re: Attaching fittings on washer style bottle...
    I live here. UR LOSN's Avatar
    Rockford, IL
    you could just use an "AN" fitting. it would go through and seal with an O ring..... and then you could use the AN to barb fitting. it would be a clean install, with zero chance of leaks.
  3. #3 Re: Attaching fittings on washer style bottle...
    Apr 2008
    Chillin at the Beach , VA
    Super glue and duct tape. It fixes everything.lol!!!JK. The only thing I can think of is what UR LOSN suggested. Everything else would make it look kind of trashy and thrown together.
  4. #4 Re: Attaching fittings on washer style bottle...
    Bastard Reptile's Avatar
    Kansas City, MO
    When I did my DO kit, I had to drill a hole slightly smaller than the threads on my fitting. Then I put a little paste on it, rubber washer on the fitting side and threaded it in. No leaks as of yet.
  5. #5 Re: Attaching fittings on washer style bottle...
    Moore, Oklahoma
    TTT.
    I know what your talking about UR LOSN, but I don't think that will work. I need something more permenent. Kinda like Reptile said.
    Anyone else??
    Shawn W. Larsen
  6. #6 Re: Attaching fittings on washer style bottle...
    Rockford, IL
    oh sure, kick me to the curb. LOL....jk!! hope you get it, thats all I could come up with...
  7. #7 Re: Attaching fittings on washer style bottle...
    Moore, Oklahoma
    Hey man, I really do appreciate you help dude. I have those same fittings on my PRJ FMHE (threaded straight w/ o-ring X -12 AN). It would would good if I could use a nut on the back side or had a boss already installed. With the thin material I don't think it would work. I would try it out, but i'd be adding $15 of fittings on a $3 bottle LOL! Although if I knew it would work good, i'd do it in a heartbeat...
    Shawn W. Larsen
  8. #8 Re: Attaching fittings on washer style bottle...
    Apr 2008
    Just some creative thought, Could you get some kind of material that would be long enough to reach and find something sticky to hold the nut enough to get it started, then use a long wrench to finish tighening it up. It seems to be easier to come up with in my head than it is to put it into actual words.
  9. #9 Re: Attaching fittings on washer style bottle...
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    JB WaterWeld
    if that doesnt do it, likely cant be done.
  10. #10 Re: Attaching fittings on washer style bottle...
    Moore, Oklahoma
    I couldn't get a nut down the filler neck, otherwise if I could do that I could tighten it somehow. Thanks for the suggestion...
    Shawn W. Larsen
  1. IC hose fittings?
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2008, 10:32 PM
  2. Changing washer bottle from 97-98 style to 99+
    By Zef_66 in forum General Tech Discussion
    Last Post: 05-30-2008, 10:03 AM
  3. Who's Done Homemade Fuel Rails (With an fittings)
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 04:13 PM
  4. Cam Question XP or VS Style?
    Last Post: 01-23-2008, 08:28 PM
  5. attaching pictures
    By Toasty in forum Forum Bugs/Suggestions
    Last Post: 01-11-2008, 04:17 PM
