Thread: Got the new DP installed, but...
Results 1 to 3 of 3
Threaded View
  1. #1 Got the new DP installed, but...
    SE Level Member the1euge's Avatar
    Apr 2008
    Pittsburgh, Pa
    I don't know if it took time to set in, or I just didn't notice or drive in a certain way to activate it but...
    when i have the car in reverse, at about 2k rpm, I get this vibrating feel and sound from my car. when i put the DP in, the clearance from the new cat to the drivers side of that heat shield was pretty close. and I do not notice anything while the vehicle is in drive. As I stated, I definitely did not notice this right after install, and has only cropped up this being about a week later.
    When the car is in reversed, does the drivetrain shift in a way that might be making my DP make contact with this heat shield? or something else maybe? Any techie tips to try and scoot it over? I've already tried those circular screw-in clamps but to no avail.
    Thank you in advance
    Edit: also when installing, i noticed i have a small hole in the resonator from one of the spot welds. i havent checked this yet as a possilbe culprit, but im not sure whw one particual gearing would cause this to engage
  1. First Mod installed. CAI
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 08:41 AM
  2. Pioneer P6000UB Installed!
    By GeddyLee in forum Audio, Security & Visual Electronics
    Last Post: 04-16-2008, 08:25 AM
  3. Just installed wizaired CAI
    By 3800SE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2008, 07:46 PM
  4. SLP Header Installed
    By J_Ferguson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2008, 03:02 PM
  5. Got my TSW Mondello's installed (sort of)
    By GeddyLee in forum Off Topic Discussion
    Last Post: 12-30-2007, 06:50 PM
