Thread: Cam Question XP or VS Style?
Results 1 to 15 of 15
  1. #1 Cam Question XP or VS Style?
    Quebec
    Well I was supposed to get a cam that had a grind very similar to the ZZP VS grind. but with some delays I've been offered an XP in place. What I'm wondering is if the XP will be too much for me & my setup?
    I've got:
    ZZP stage 1 TB
    Ported Gen3 & LIM
    SLP headers
    Full custom exhaust
    JMB FWI
    HPTuners (with all the extra goodies)
    The thing is that I just got myself a brand new OEM timing chian & gaskets to install the other cam. I'm still planning on usign the same springs (105's) with the XP, but will the stock timing chain be ok?
    I also liked the fact that the VS style cam made better low end to mid power & I'm wondering if the fact that the XP's power being closer to the top end & with my car being a daily driver it may not be as beneficial. I'm hoping to get some insight for others.
    Finally I'm still on stock injectors, I assume that with the XP I may be to close to static with them? (I do have the fuel pump hotwire, but also the stock pump). I was planning on starting my tuning with a 3.2" pully this spring.
    2000 GTP - Getting Faster All The Time
  2. #2 Re: Cam Question XP or VS Style?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    IF you have stock gearing (2.93), I wouldn't get an XP. I don't like mine in the in the low to mid range, even with 3.29 gearing.
    Yes you can, and I would, run the stock chain and tensioner.
    Injectors may be iffy, especially with a 3.2 pulley.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Cam Question XP or VS Style?
    Quebec
    That was my first & main worry that the cam would be too much for my setup, since I'm not as fimilar with the 3.8 I wanted to be sure before making any decision on weather or not to take the XP.
  4. #4 Re: Cam Question XP or VS Style?
    St Louis MO
    Quote Originally Posted by RNUOVR View Post
    It's not too much for your setup, it's just that the low to mid range suffers a bit and w/o 3.29 gearing it would be even worse than mine.
    2010 Camaro SS LS3
  5. #5 Re: Cam Question XP or VS Style?
    Quebec
    With the car being more of a driver over a race car (actually already have one of those, race care that is & with plans to get a 2nd) & with what you said IndeedSS I really don't like the fact that I'll be giving up low & mid end, especially with the stock tranny & no plans of upgrading the tranny gears or convertor any time soon.
    Anyone else out there that has an XP with a stock tranny are your feelings the same?
    I'm hearing that the s1x would be better (more cam than the one I was supposed to get, but less than the XP).
  6. #6 Re: Cam Question XP or VS Style?
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    http://www.grandprixforums.net/f18/t...-step-819.html
    Try that thread it actually has good info on cams, if you ignore all the bs'ing between us.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  7. #7 Re: Cam Question XP or VS Style?
    Quebec
    Cool, thanks for that link. I think I remembered reading the start of that thread when I was deciding on a cam, but it was hardlt 2 pages long then. Well I think that I was right with my decision the 1st time, after reading I think that the XP is just not going to be what I want & it's specs arn't what I'd need it to do (light to med acceleration, traffic & just regular daily driving).
  8. #8 Re: Cam Question XP or VS Style?
    chicago
    i don't think you going to like vs after awhile. xp is a way to go. i have xp and i love it and mine is a dd. check out this vid.
    http://www.grandprixforums.net/f51/t...an95-1178.html
  9. #9 Re: Cam Question XP or VS Style?
    St Louis MO
    Quote Originally Posted by 38special View Post
    Do you drive in a lot of stop and go traffic? Or where you need to make a quick lane change but the slot you are moving into is small enough you can't put the pedal down very far? Hmmm. it just occured to me you are the one that just switched. Give it a little time.
    2010 Camaro SS LS3
  10. #10 Re: Cam Question XP or VS Style?
    chicago
    i work in the suburb and yeah there some stop and go and as far as gas mileage it not as bad. beside i got the xp for a reason. if you worry about gas and other craps might as well keep it stock. look at cars coming out from the factory they keep getting faster and faster. gotta keep with the compitition. beside i don't beat up on my car like most people maybe once in awhile and man it feel good beating a corvette. btw lee i have the xp since last year i think that's enough time. my father had a vs cam in his gtp for 7 months and guess he don't like it. he now just switch to xp last weekend.
  11. #11 Re: Cam Question XP or VS Style?
    GT Level Member DuBob's Avatar
    Lititz, PA
    Like I've mentioned many times, I've had both the VS and the XP and for my driving style, I really liked the VS.
    One of the First: 2008 Liquid Red Pontiac G8 GT (hers)
    -Intake, Tune, Magnaflow Exhaust, 40% tint.
    -Next: Rims, lowered?, headers?
    One of the Last: 2009.5 Stryker Blue Metallic Pontiac G8 GXP M6 (mine)
    -Intake, Magnaflow Exhaust, 25% tint.
    -Next: Headers and tune.
  12. #12 Re: Cam Question XP or VS Style?
    St Louis MO
    I understand you are running the stock timing chain? I wonder if that -2* cam is hurting me that much? I would have thought the 3.29 gearing would have trumped the retarded timing, but apparently not.
    I've not been real happy with my XP under normal driving conditions since the day I picked it up. Actually the first time I went to pass a truck using light throttle on my way home I could tell there was a noticable drop in performance versus my stock cam. Now anything above medium throttle or at high rpms is excellent. Many other people have noticed this about the XP, but I bet all of them went aftermarket timing sets like I did. We are going to remedy this situation though.
    2010 Camaro SS LS3
  13. #13 Re: Cam Question XP or VS Style?
    St Louis MO
    Quote Originally Posted by DuBob View Post
    Dave, what timing set were you using?
    2010 Camaro SS LS3
  14. #14 Re: Cam Question XP or VS Style?
    Lititz, PA
    single rollmaster. I'd like to see pictures as proof of the whole "-2*" thing.
  15. #15 Re: Cam Question XP or VS Style?
    St Louis MO
    I can't confirm the actual number of -2*. However, it has been confirmed, by the former GM engineers at Thrasher, the goto guy at JP that there is a difference in the cam timing between the L36 and L67. JP and and Rollmaster are both Aussie companies and I don't know who it was that confirmed the Rollmaster was designed for the 3.8l NA and not the supercharged version. At least two people on this forum have confirmed that there is indeed a timing difference between the L36 and L67 by comparing the gears and are looknig further into how much difference. If you look at Intenses site you can see that the gears are different on the GM replacements.
    2010 Camaro SS LS3
  1. synco question
    By UR LOSN in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 08-09-2009, 11:57 PM
  2. What brand/style of tires are you running?
    By John02Hawk in forum Tires & Wheels
    Last Post: 02-15-2008, 01:18 AM
  3. TOG Header Question...
    By Iron Indian in forum General Tech Discussion
    Last Post: 01-09-2008, 01:00 AM
  4. LS1 brake question
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2008, 12:14 PM
  5. 04 and up pcm question
    By nemesis in forum PCM Tuning
    Last Post: 01-04-2008, 11:07 PM
