Thread: Starter Question
Results 1 to 6 of 6
  1. #1 Starter Question
    Apr 2009
    San Jose, Ca
    Hey fellas, is this supposed to happen on a starter? The video link is below. Thanks.
    b267de18.mp4 video by skunktriscuit - Photobucket
  2. #2 Re: Starter Question
    I'm pretty sure it is
  3. #3 Re: Starter Question
    looks broke to me.
    that gear should only go out when the starter gets power to then turn the flywheel
  4. #4 Re: Starter Question
    thats broken.
    take the solenoid off and look into it, there's a rod that catches that spur gear, (the one sliding in the vid) it may have broke. when you turn the key this rod pushes out the spur gear and it turns the flywheel, then pulls it back when you let the key go. i used to be able to fix these years ago when i was a broke kid,(im still broke) they still look serviceable. witch is still cheaper than a new starter.
  5. #5 Re: Starter Question
    found a vid of a starter being taken apart, there's not much to a rebuild as you could see. ‪Starter motor disassembly‬‏ - YouTube
  6. #6 Re: Starter Question
    Apr 2009
    San Jose, Ca
    Thanks fellas, i'm also thinking that its broke. I took it to autozone and they said it wasn't supposed to do that. Again, thanks for the input.
  1. HELP Starter?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 12-26-2010, 10:04 PM
  2. starter help
    By R3B3L 91 in forum General Tech Discussion
    Last Post: 10-26-2010, 12:37 PM
  3. Need help with a starter...
    By kcbuckeye2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 12:14 PM
  4. Valet 552t remote starter question
    By shawnz90 in forum Audio, Security & Visual Electronics
    Last Post: 10-27-2009, 09:40 AM
