Who's done this? Top or bottom install? tips on doing so?
I have SD Headers waiting about 2 weeks to go on.
I know i have a LOT of AC/Coolant related lines directly behind the motor that run into the firewall. I'm not sure if they exist in such a location on the GTP/Regal/etc. At least the coolant (for the heater core) appear to be easily removable but the AC one is sketchy. there's also the engine bracket which seems easy enough to remove.
Option B is removing the 4 rear cradle bolts and letting it down a couple inches or whatever to install from underneath. I've NEVER done this before so im skeptical at best. Prefer feedback if anyone had gone that route and the steps it took/what you did.
Since the TB/intake has to come off I also have a ported blower case i plan to do at the same time. Would it be beneficial to remove everything for the blower swap first, then while blower is off install headers, then finish blower? would i gain any room by doing it in that order?
--- It's a 99
