Not sure where B town is.. but if you are on the east side of the state and want a hand, stop on over.
As for install.
Jack and support the car.
Pull off the crossover at both ends.
Remove front manfold (might be a 13mm or 15mm holding that shield on the passenger end of the motor under the ...or just above the idler pulley)
Reach down or get under with an extension and swivel and pull the downpipe and rear manifold out.
Wiggle rear manifold out the bottom.
Wiggle new rear manifold in from the bottom.
Bolt up
Slide clamps and crossover in
Start front manifold and wiggle/tap (rubber mallet) on crossover to seat evertyhing.
Clamp and go drive.
There's no need to pull the TB, air tube or airbox. It's that easy and that large of a car that you'll have an easy time. No need to drop the cradle in most non-W body cases.
