Thread: leaking from somewere!
Results 1 to 20 of 23
  1. #1 leaking from somewere!
    GT Level Member gunsn88's Avatar
    May 2011
    Vineland, New Jersey, United States
    hi i have a 01 gp gt and theres a leak under my car coming near from near the passenger side front tire, its driping from the transmition or around that. i dont know if its coolant or trany fluid. i checked the coolent before i did have a leak but thats fixed. and slowly my trany fluid level is droping. the transmition guy told me not to change the fluid or anything eve though the fluid looks burnt. any pointers please. e said if i change the fluid or anything i can actually make the trany werse. everything runs fine but that leak
  2. #2 Re: leaking from somewere!
    What color is the fluid. Is it oily or is it watery?
  3. #3 Re: leaking from somewere!
    PA
    Figure out what the fluid is, then we can help pinpoint it better.
    2001 GSE
  4. #4 Re: leaking from somewere!
    It can only be
    Power steerign fluid
    Trans fluid
    Coolant
    Brake fluid
    Fuel
    Anything beyond that..and you got an interestig leak.
  5. #5 Re: leaking from somewere!
    PA
    It can only be
    Trans fluid
    Coolant
    Brake fluid
    Fuel
    The motor mount could be leaking.
    2001 GSE
  6. #6 Re: leaking from somewere!
    Quote Originally Posted by Zef_66 View Post
    There's not enough fluid there to leave decent puddles. Same for the SC oil. I thought about them.
  7. #7 Re: leaking from somewere!
    Panama City Beach, FL
    It can only be
    Trans fluid
    Coolant
    Brake fluid
    Fuel
    Urine.
  8. #8 Re: leaking from somewere!
    May 2011
    thanks guys for all the advice. im first going t ocheck my tranny and change the fluid and get a new gascet. i got transx for it so adding the additive should be better then nothing at all. ill see were it goes from there. and now i got another isue my service engine light came on again and its code 420, converter failure, but i just got a new magnaflow converter and resinater. im confused and getting pissed lol
  9. #9 Re: leaking from somewere!
    Grand Island, Nebraska
    The code is because its a high flow cat, so the car thinks its not working correctly. If its a brand new cat you are fine. you just wont be able to see any other engine codes.
  10. #10 Re: leaking from somewere!
    May 2011
    so how can i pass inspection with the check engine light one? i deleat it with the scanner
  11. #11 Re: leaking from somewere!
    Quote Originally Posted by gunsn88 View Post
    Find someone with HPT, delete reporting of the emissions related bullshiz, and be done.
  12. #12 Re: leaking from somewere!
    are you in New Jersey? if so im pretty sure there are a few guys in the state (possibly south jersey) who may be able to tune your pcm.
    i'd start a new thread and call it looking for a tuner in new jersey. there should be someone who could help you out for a few bucks.
    sure you could get a caned tune but you would need to send them your pcm, and wait for it to come back,(and be car less) unless you buy a used pcm and send that one off, either way it will cost more than finding a local guy to turn off the o2 sensor reporting.
  13. #13 Re: leaking from somewere!
    If you delete it, it will come back eventually. You have to get the code taken out with a tuner.
  14. #14 Re: leaking from somewere!
    May 2011
    how about if i get amoded ecm from 3800.com or something, i cant find any chips or scanners thatll work on the grand prixes but the moded ecms.
  15. #15 Re: leaking from somewere!
    I live here. TLSheff's Avatar
    Being a 01 its debatable on whether or not the 3800 02 emulator will work. Some say it does some say not. You could try if you have the $60 +shipping. If it doesn't work or if you don't want to try, just scan it off and on to keep on top of the car or get it tuned to turn it off. Someone may be in the surrounding area with a programmer, that would work to turn it off if you can find someone
    02 Emulator - Rear O2 Emulator: 3800 Performance
  16. #16 Re: leaking from somewere!
    May 2011
    ive been scaning it and turning it off but the moter vehicle guys failed me on emitions because of it, i really would like a super chip or something to work with it though.
  17. #17 Re: leaking from somewere!
    Jun 2011
    Detroit, MI
    Is it oil?
    iLoveSpade
  18. #18 Re: leaking from somewere!
    moved
  19. #19 Re: leaking from somewere!
    May 2011
    its not oil no, its to liquidy to be oil. ive read that the heads leak coolant sometimes or the power steering could have a leak, this is just what ive looked up, its hard to check under all that because its so packed under the hood and under neath. im use to working on an 83 mote carlo when i got this newer car it was like other world tech for me lol
  20. #20 Re: leaking from somewere!
    May 2011
    sounds good, ill post the thread about it now. thank yo ufor all the help
  1. leaking pan
    By tdm571 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2011, 03:18 PM
  2. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  3. leaking coolant
    By pacothetaco in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2010, 11:25 AM
  4. leaking air
    By nyydmb12 in forum Tires & Wheels
    Last Post: 07-14-2009, 07:39 AM
  5. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
