Thread: leaking from somewere!
Results 1 to 20 of 23
  1. #1 Re: leaking from somewere!
    PA
    Figure out what the fluid is, then we can help pinpoint it better.
    2001 GSE
  2. #2 Re: leaking from somewere!
    It can only be
    Power steerign fluid
    Trans fluid
    Coolant
    Brake fluid
    Fuel
    Anything beyond that..and you got an interestig leak.
  3. #3 Re: leaking from somewere!
    PA
    It can only be
    Trans fluid
    Coolant
    Brake fluid
    Fuel
    The motor mount could be leaking.
    2001 GSE
  4. #4 Re: leaking from somewere!
    Quote Originally Posted by Zef_66 View Post
    There's not enough fluid there to leave decent puddles. Same for the SC oil. I thought about them.
  5. #5 Re: leaking from somewere!
    when my oil pressure sensor went bad it leaked right onto where the axle shaft enters the trans, scared the hell out of me when it happened, i thought it was the trans leaking till i looked up and saw the sensor leaking like mad.
  6. #6 Re: leaking from somewere!
    PA
    He didn't say it was a decent sized puddle. Just that it was leaking. You need to start covering all your bases, Bill. You know better than that.
    But to the OP, you mention that the tranny fluid is going getting low. If you have a leak, and you notice that one of your fluids is getting lower, I would put my money there first.
    As for not changing the fluid on the tranny, I don't agree with that. If it were me, I would drop the pan and change the filter and replace the fluid that you loose. It will only change out about 50% of the fluid in the tranny and allow the old to mix nicely with the new. The issue comes with an old, beaten, hurt tranny that someone tries to replace all the fluid at once. It is a shock to the transmission and usually not recommended. I would venture that is what your mechanic is talking about.
    2001 GSE
  7. #7 Re: leaking from somewere!
    Zef, I hear ya. Would you buy into me having telepathy? I'll play that card if you guys would buy it. lol Something about the way he said tire and dripping etc made me feel like it was a decent amount. Having zipped into a mount before...I went on gut feeling. I'm also really tired today. Should be doing work...but you know.
  8. #8 Re: leaking from somewere!
    Panama City Beach, FL
    It can only be
    Trans fluid
    Coolant
    Brake fluid
    Fuel
    Urine.
  1. leaking pan
    By tdm571 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2011, 03:18 PM
  2. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  3. leaking coolant
    By pacothetaco in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2010, 11:25 AM
  4. leaking air
    By nyydmb12 in forum Tires & Wheels
    Last Post: 07-14-2009, 07:39 AM
  5. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
